RV.Net Open Roads Forum: Travel Trailers: 20' KeyStone Hideout Mach15 dripping inside...
 > 20' KeyStone Hideout Mach15 dripping inside...
Matt1221
Posted: 06/19/21 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Best solutions for this problem? I did a quick search on mach 15 leaking inside trailer and didn't find anything. Just woke up today with the floor all wet & a/c dripping on the inside, it's a 2020 hideout with very little road time. Thank you
Gooma
Iowa
Posted: 06/19/21 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
The AC is not draining properly. Roof air? Drain line clogged. Wall air? Not tilted toward outside.
Near DVNP, California
Posted: 06/19/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Remember that “road time” and “sit time” are about equal for leaks.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Matt1221
Posted: 06/19/21 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
I assume the drain is clogged i was going to pull the cover off and look, but i don't feel comfortable digging too deep. But no ladder at the moment, my mistake I had always assumed they come with one & didn't realize ours didn't have one built onto it, lol.
Sjm9911
New Jersey
Posted: 06/19/21 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
Could be the gasket also, or it froze up and defeosted. You need to check it all.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Matt1221
Posted: 06/19/21 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
I don't believe it froze over cause it only lets water out while it's running. We have let it set a couple hrs it spews water right afterwards.. now that I've done more research, it's most likely a stopped up evap drain tray or possible a cracked drain tray (worst case scenario)
flguppie
Treasure Coast-FL
Posted: 06/19/21 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Inside the RV remove the cover and tighten the 4 mounting bolts a quarter turn. The unit has more than likely vibrated a little loose and water on the roof is leaking in under the gasket. Don’t over tighten.
FL-Guppie "small fish in a big pond"
2014 KZSpree Connect 220rbk
2018 Ford F150 SuperCrew 3.5L Ecoboost, maxtow
afidel
Cleveland
Posted: 06/19/21 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
If it didn't come with a ladder then there's a 99% chance the roof isn't rated to be walked on, if you go up to inspect use a piece of plywood to spread out your weight over multiple trusses.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
Nv Guy
Reno NV
Posted: 06/19/21 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
Low fan speed / restricted air flow and high humidity will cause icing / freeze up.
Also- as mentioned, no ladder = no walk roof. That's how the manufacturer tells you to stay off, so also as previously mentioned use plywood to spread the load.
B-n-B
Colorado
Posted: 06/20/21 11:14am Link  |  Quote  |  Print  |  Notify Moderator
For what it’s worth my TT didn’t come with a ladder either. I had heard the theory it meant my roof couldn’t be walked on. I called Heartland directly and asked about walking on my roof. The tech replied it was no problem. He also offered there is no such thing as a “no walk on roof.” If there were, no RVs would have AC or vents up top. Also roofs needed to be walked on to perform preventative maintenance. Some RVs just don’t come with ladders.
After the phone call I proceeded to install 400W of solar, a fantastic fan and a skylight while walking on my roof.
2006 Ram 3500 Big Horn SRW 4x4
5.9L Cummins
2021 Sundance 189MB
