RV.Net Open Roads Forum: Technology Corner: Long Range Two Way Radio
 > Long Range Two Way Radio
azdryheat
Tucson, AZ
Posted: 06/19/21 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Check out satellite radios, they operate anywhere.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
burkhall1
Kutztown, PA
Posted: 06/20/21 06:27am Link  |  Quote  |  Print  |  Notify Moderator
All,
Thanks very much for the feedback!
ktmrfs, after my research, I'm like the GRMS together with MURS. What make/model do you have? I'm considering a Tera TR-505.
ktmrfs
Portland, Oregon
Posted: 06/20/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
burkhall1 wrote:
All,
In the cars and for around camp we have rugged radio RH5R, one of the no longer sold units due to FCC crackdown on the non compliant radios. Programmed for MURS, FRS and GRMS
for off road riding etc. we have Standard Horizon HX370 or HX400 programmed for MURS channels and FRS channels. Standard horizon is single band only so no GRMS channels.
On both I programmed them with tone controlled squelch on the channels as well as the non tone controlled squelch on the same channels.
2011 Keystone Outback 295RE
Sagebrush
Jacksonville AL
Posted: 06/20/21 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Even as an Amateur Radio operator with the option of having more powerful transceivers the range isn't much better with a 6 watt or stronger Handy Talkie. For battery life we run the HT's at the lower power settings and use wire J pole antennas you can throw up in a tree or get up high somehow. Power doesn't do that much with a hand held. Rubber duck antennas are very limited. I use the base loaded wire antenna from Comet on my little HT instead of the stock plastic antenna. It does help... I think. But its still line of sight, get a cheap FRS radio and call it a day or become a Tech rated Amateur Radio operator for more options. [emoticon]
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 06/20/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
We have a set of Cobra radios, advertised as maximum range of 35 miles in ideal conditions (up to two miles in urban conditions) don't believe it a mile maybe two under the right conditions and that's it.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Fisherman
Angus, Ontario, Canada
Posted: 06/20/21 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
Have to agree about the companies opinionated hope to get past a couple miles at best. I think they did their testing in outer space with absolutely no interference.
ktmrfs
Portland, Oregon
Posted: 06/20/21 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
just about correct. Range for some, maybe all, is listed for the conditions that one radio is on a high elevation and able to look directly downward to the other radio with nothing in the path, zip, nada, not a tree, not a rock outcropping nothing.
And as some others have mentioned, 5W gives a limited range, especially with the "rubber ducky" antennas. On mine I have loaded, matched, wavelength matched antennas.
enblethen
Moses Lake, WA
Posted: 06/20/21 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Cobra radios have different power output depending on channel. How much it changes range, I do not know!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rk911
DuPage County
Posted: 06/20/21 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
assuming everything else is equal less power = shorter range.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Alan_Hepburn
San Jose, Ca, USA
Posted: 06/21/21 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
burkhall1 wrote:
All,
I just picked up a Midland MXT275 GMRS package from Amazon - haven't had a chance to install or test it yet, but it gets good reviews on the various off-road forums I've checked.
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
