RV.Net Open Roads Forum: Tech Issues: Mini Swamp Cooler (Arctic Air) - Legit?
 > Mini Swamp Cooler (Arctic Air) - Legit?
Baja Man
Inland Empire, CA
Posted: 06/19/21 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
I live in HOT area of So Cal Desert! We enjoy camping in Southwest states in summers. It can get hot (100-110f). My AC is a 13.5 in a 25' trailer (29' overall).
Have any of you used this product.....Does it work as advertised?
https://www.arcticairpurechill.com/
Thought of placing near beds, dinette. I believe it's too big to place behind refer below condenser to help refer.
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
stickdog
Somewhere, USA
Posted: 06/19/21 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
If it sounds too good it probably is.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
3 tons
NV.
Posted: 06/19/21 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
I see little risk (at $40’ish), I cant attest to the durability but the swamp cooler principle has been well vetted for about a century…A nice back up when the generator wont start the air conditioner…
3 tons
bigorange
Tucson, AZ
Posted: 06/19/21 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
I’m sure it works, I just wouldn’t expect it to put out a lot of cool air. I’ve used large portable swamp coolers and they work well and move a lot of air.
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
pconroy328
Colorado
Posted: 06/20/21 12:27am Link  |  Quote  |  Print  |  Notify Moderator
Search youtube and the 'net. Dozens and dozens of people in RVs who say it's largely a waste of money. The last thing I need in my RV, on a hot day, is more humidity in the air.
Bumpyroad
Virginia
Posted: 06/20/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
3 tons
and for only 20 bucks more you can get a second one.
bumpy
Roger10378
Goodrich, MI.
Posted: 06/20/21 06:33am Link  |  Quote  |  Print  |  Notify Moderator
In general swamp coolers work well in arid climates, but don't work at all in humid climates. I think this is not understood by many people which is you get such varied opinion from people. I also think that the sellers of these type of system should do a better job of pointing out where they will and won't work. If you read most of the advertisements they are always great.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
BobsYourUncle
Calgary Alberta Canada
Posted: 06/20/21 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Back in the day before I could afford AC I made my own simple swamp cooler.
A plastic tub, couple blocks of ice, and a fan. Done.
It actually worked amazingly well.
Gotta have a supply of block ice though. Works better than just water.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Posted: 06/20/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Have used a couple of those devices
They do work
Not as well as advertised in most cases
but they do work.
They work best in "Dry" Climates
And the science behind them is solid
Short of failure of the pump or blower there is almost no way they can not work.
valhalla360
No paticular place.
Posted: 06/20/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Blowing air across a block of ice is not a swamp cooler.
Swamp coolers rely on evaporation. The phase change from liquid to gas absorbs heat.
They work well in low humidity environments as evaporation can occur rapidly absorbing lots of heat. They do add humidity to the air but that's often a good thing in arid environments.
In a humid environments, evaporation occurs much more slowly to the point where they offer negligible cooling and they make the already muggy air even more moist.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
