RV.Net Open Roads Forum: Fifth-Wheels: F250 or F350 to Haul a 5th Wheel???
 > F250 or F350 to Haul a 5th Wheel???
Matias44
samoa
Posted: 06/20/21 02:43am Link  |  Quote  |  Print  |  Notify Moderator
Hello-
I would appreciate your advice on the size of truck to haul a 5th wheel.
We are about to purchase our first 5th Wheel (2018 Jayco Northpoint 377RLBH with GVWR 16750) for a multi-state 6month trip around the country with my wife and 2 daughters.
We are new to 5th wheels, but experienced campers/RVers.
We are looking for advice for the type of truck to safely haul this beast.
We've narrowed down to Ford.
Would you recommend an F350 or would an F250 be safe to haul up and down the mountains? Gas or diesel?
Thank you in advance!
tplinklogin
sarkari job
* This post was edited 07/03/21 12:53am by Matias44 *
MFL
Midwest
Posted: 06/20/21 05:00am Link  |  Quote  |  Print  |  Notify Moderator
The answer is so obvious, it may be a troll post??
Okay...the obvious answer is the 350, and with 3 girls on a long trip, you will need a 350 with 6 wheels.
No question, the diesel is also an obvious choice!
Jerry
Coach-man
Posted: 06/20/21 05:57am Link  |  Quote  |  Print  |  Notify Moderator
With that weighty out will need a one ton vehicle. If you insist on a Ford, a 450 would be a better option. Check out a RAM 3500, when a truck gets picked as “car of the year”, they are trying to tell you something!,
jaycocamprs
Ringgold Georgia
Posted: 06/20/21 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Your going to want a diesel to pull the load in the mountains. And your going to NEED a Dual Rear Wheel truck to carry the LOADED pin weight. That trailer could be around 4K for a fully loaded pin, plus the 4 people & stuff in the truck.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
phillyg
SWFL
Posted: 06/20/21 06:51am Link  |  Quote  |  Print  |  Notify Moderator
My older F350 SRW would be maxxed out if the FW was loaded to its 16,000 gross. You're definitely in one ton range, and you'd be better off with a dually.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Monterey, California
Posted: 06/20/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Not all 250s are equal. Same with 350s. But at a max 17000 pounds, no question…350.
RetiredRealtorRick
Gulf Shores, AL
Posted: 06/20/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Definitely an F350 dually diesel. No question.
Are there many places to RV on a 1000 square mile island?? Just curious.
. . . never confuse education with intelligence
Mike134
Elgin, IL
Posted: 06/20/21 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Myself I'd get a gas 350 single. Don't have to fight the hips of a dually around town. Save about 750 lbs with the 7.3 motor. Diesel makes sense if you'll put 300,000 miles on the motor otherwise the upfront costs/maintence costs are just to much.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Walaby
Georgia
Posted: 06/20/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
That weight is clearly dually territory.
My 5er has 15K GVWR. I have a SRW but I wouldn't go any higher and I don't max out the weight.
Nearly 2K higher is definitely six wheel and no doubt diesel.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
4x4ord
Alberta
Posted: 06/20/21 08:47am Link  |  Quote  |  Print  |  Notify Moderator
If you’re looking at new, a srw gas would do. I’d want a diesel srw for that size trailer. If you opt for a 250 you might have to add air bags.
2021 F350 SRW Platinum short box 4x4.
B&W Companion
