RV.Net Open Roads Forum: Travel Trailers: Hitch Selection - TW Questions
 > Hitch Selection - TW Questions
Baja Man
Inland Empire, CA
Posted: 06/20/21 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
I have used both Equalizer brand and Blue Ox. EQ made quite a bot of screeching sounds. BO was quiet. They both worked great.
Considering both with my new to me TT (2011 Outback 250RS). GVWR of 7550#; It has a brochure TW of 640#. After I load trailer and full water tank (50Ga), I would assume it will be between 700-1100. I have a TW scale and will weigh before I decide on which model rated bars/head unit.
My questions are:
1. If TW loaded is 900#-1200#....will a 1500# rated bars to stiff for the application?
2. How much over loaded TW should the hitch size (head/bars) be?
3. Bars (EQ/BO) vs Chains (BO)?
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
rexlion
Broken Arrow OK
Posted: 06/20/21 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
I'd figure what my greatest anticipated tongue weight might be, and get whatever is enough (even 'just enough') to handle that amount. Going beyond that to the next available pound-rated hitch could cause a rougher ride, and maybe somewhat more stress on the frames for lack of 'give'. However, if you think you'll be trading the trailer for something heavier in the near future, then it could make sense to go to the next higher rated hitch.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
Posted: 06/20/21 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
1000lb giver take tongue weight on a F350?
I’d use the Invisible WDH…
2017 Heartland Torque T29
Mickeyfan0805
SE Wisconsin
Posted: 06/21/21 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I agree with rexilon. With that GVWR, even a 15% hitch weight would be under 1,200 pounds. That would likely be my target. The only caveat would be gear in the bed. If you are heavily loading your bed, that does come into the equation and might change the need.
Boomerweps
Hills of PA
Posted: 06/21/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
The bar only, non chain types usually have anti-sway built in, no need for external anti-sway units. No need to remove anti-sway bars when backing up.
Equalizer sells a plastic pad for the spring bars to rest on, cutting the screaching significantly..
Recommend taking your TT GVWR times 10% and 15%. Get bars within that range.
To repeat an oft posted story. With full FW tank (accidentally left full) my 3877# GVWR TT tongue weight was about 680# by Haulgauge last fall. My spring bars are 400-600# rated. So a little stronger than anticipated need is not a bad thing.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
kellem
Shenandoah valley,VA
Posted: 06/21/21 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Have a 7600# trailer and use 1200# trunnion bars without issue.
Usually carry a bed load and full fresh water tank (60g).
The FWT is located well forward of the axles, something to consider.
wowens79
Georgia
Posted: 06/21/21 10:40am Link  |  Quote  |  Print  |  Notify Moderator
When i was buying my Blue Ox, I was on the border between sizes and emailed Blue Ox, and they said to go with the heavier bars if in doubt.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
Posted: 06/21/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
I have a 12,800lb gvw trailer, running about 10k ready to camp and use 0# trunnions bars without issue. Tows like it’s on rails.
Still not sure where the brainwashing comes from, but OP ought to tow his trailer first then decide what he wants or needs.
kellem
Posted: 06/21/21 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
No brainwashing coming from this direction.
I'm towing a scale weight 7600# trailer with a 3/4 ton and much prefer having weight distributed to front axle and also run under speed limit.....err on the side of caution kinda guy.
Baja Man
Inland Empire, CA
Posted: 06/21/21 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Based on one of the responses...
Does weight in truck bed need to be considered when selecting a WDH?
Ex. TW is 900# and truck bed has 500#....hitch and bars need a 1400# rating?
Chains vs solid bars?
