RV.Net Open Roads Forum: Can tires be off ground on auto leveling system?
 > Can tires be off ground on auto leveling system?
mrad
Prineton, MN
Posted: 06/21/21 11:10pm Link  |  Quote  |  Print  |  Notify Moderator
when we pulled into our campground yesterday, the auto-leveling system was off a bit. I had to raise one side a bit and then noticed that two of the tires on one side were between 1/4 and 1/2 inch off the ground.
I don't feel comfortable with this, but since this is the third time out with our 5th wheel, I wanted to know if this is acceptable, or if I need to make some adjustments.
rk911
DuPage County
Posted: 06/21/21 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
i don't like that either so i carry 8 pieces of plywood in assorted thicknesses to use under the tire(s) when that happens.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
CA Traveler
The Western States
Posted: 06/21/21 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
With tires off of the ground any tire locking mechanism isn't effective.
2014 Grand Cherokee Overland
Bob
pennysmom09
Delaware
Posted: 06/22/21 05:37am Link  |  Quote  |  Print  |  Notify Moderator
Since we’ve parked this way quite often and had no issues when lowered, it seems safe to assume it causes no harm.
Nancy and Doug
2015 KZ Durango 325RL FW
Posted: 06/22/21 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Motor homes
There are those who claim lifting the front tires off the ground will damage the suspension.. This is Male Bovine Produced Organic Fertilizer (BS) as the suspension system won't have any issues with it unless the suspension is worn beyond need for replacement.
HOWEVER only one tire not both Reason follows
And on the rear.. Most Motor homes use drive shaft parking brakes So if one wheel is off the ground there is no parking brake as that wheel can turn freely.
So if you have both front, (or one rear) wheel off the ground and there is a "Stiff breeze" say 80-100 MPH (Been there 4 down) You may get blown away.
IN fact it it would take a whole lot less than 80mph. as little as 5-10 can do it.
Trailers... No parking brakes so the above does not apply
BUT I'd still not want to have both sides off the ground as.. Well.. the jacks are not really designed for that kind of support and it's way to easy to pretzel them.
D.E.Bishop
Eagle Rock, CA
Posted: 06/22/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
I have never seen a leveling system that had lateral support built into it. Leveling systems by name, indicate vertical support not foundational support.
Disclaimer: Just because I have not seen one does not indicate they do not exist.
Your question had to do with a trailer and I have very limited experience in that area but safety first is always best. I would not raise my Motorhome off the ground with the hydraulic jacks.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
Lantley
Ellicott City, Maryland
Posted: 06/22/21 05:56am Link  |  Quote  |  Print  |  Notify Moderator
I put block under the wheels if the site is so unlevel that the level system lifts them off the ground when leveling. I do not want all the weight solely on the jacks.
I do not believe the jacks are robust enough to support the weight.
I take the "Better safe than sorry approach."
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
phillyg
SWFL
Posted: 06/22/21 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Have had a couple of instances where the tires were off the ground, I had no wood, and I was fine for a few days' stay. I don't think its a big deal.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
StirCrazy
Kamloops, BC, Canada
Posted: 06/22/21 06:41am Link  |  Quote  |  Print  |  Notify Moderator
your leveling system will in most cases take most of the weight off the tires when it does its thing. at least mine does, thats why they are so solid compared to the ols hand jacks we used to put down. if I am in a very unlevel site it will usaly lift one set of tires off the ground depending on how good a job I do with my blocks. it has never bothered me and still feels exactly the same inside..
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
ford truck guy
Pennsylvania
Posted: 06/22/21 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I am with philyg . .
When I can, I will use a blocks of wood to get the fifth wheel "more level" before using the 6 point system...
But like stated, there are times that I did not realize it and unhooked and hit auto level. The result was 1 side being anywhere from 1/2" up to 1" off the ground with no ILL effects.
Not to mention...my 6 jack cylinders are rated at 8,000# EACH... with the RV only being 16,500# loaded, the system is well within its capacities
* This post was edited 06/22/21 06:48am by ford truck guy *
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
