RV.Net Open Roads Forum: Dinghy Towing: towing a Smart Car
Search only in Dinghy Towing
 > towing a Smart Car
oldladyhoo
Green Valley, AZ
Posted: 06/22/21 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have just bought a 2014 Winnebago class C and want to tow a 2007 Smart car. I have gotten 10 different stories on no or yes that I can. I called the Mercedes dealer in Phoenix which the only one in the state of AZ. They say no I cannot flat tow it. They told me that it had to have been imported because they started shipping cars to the US in 2008. It is a fourtwo and it would make the great run around car for two old widows that are going to start RVing. Any suggestions or info on this subject would be appreciated. Hope you see you down the road.
Tom_M
New Hope, MN
Posted: 06/23/21 03:17am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2013 and it tows well. Once hooked up put transmission in neutral while engine is running. Turn ignition off and wait until instrument panel goes dark (this is crucial) then disconnect battery. I installed a disconnect switch. There is no steering lock to contend with. The key must remain in the switch. You also need to attach a bungee cord to the steering wheel. Without the bungee steering may go lock to lock after making a sharp turn like around a street corner and you have to come to a complete stop to make it quit.
When you reconnect the battery and turn the ignition on the transmission goes through some kind of calibration sequence and you can not start the car until it finishes.
* This post was edited 06/23/21 03:34am by Tom_M *
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
bikendan
Goodyear, Arizona
Posted: 06/23/21 03:41am Link  |  Quote  |  Print  |  Notify Moderator
thread should be moved to Dinghy Towing section
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
fj12ryder
Platte City, MO
Posted: 06/23/21 06:25am Link  |  Quote  |  Print  |  Notify Moderator
FWIW, I have seen some towed four down, but no idea of the year.
Howard and Peggy
"Don't Panic"
ferndaleflyer
everywhere
Posted: 06/23/21 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Ok folks. I have a 2014 Smart and have towed it probably 15,000mi around the eastern US. I use a dolly. It takes 5min to load it and put it out of gear and hit the road. No unhooked battery, bungy on the steering wheel, etc. Just strap it down leave the key on and transmission out of gear. Its pretty simple. By the way good luck finding someone, even a Mercedes dealer, to work on it. Seems to scare them. But it is a good car to travel with as it is so light, about 1800lbs, and small and easy to park where others can't. Make it simple. Hope this helps.
Southern California :(
Posted: 06/23/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Don’t follow anything but the manufacturer’s mandates. Yes, you may need a dolly.
BarneyS
S.E. Lower Michigan
Posted: 06/23/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Moved to Dinghy Towing forum from Towing.
Y-Guy
Tri-Cities, WA
Posted: 06/23/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
The ultimate authority is the actual Owners Manual that came with the vehicle. In most cases you can do a Google Search with the year make and model to find one online. But you will want to verify with the actual owners manual of that vehicle to be sure since sometimes the online ones might differ from the actual. Generally speaking you want to look for the section on "Recreational Towing" in the owners manual.
There are users that find out that they can tow four down just fine, going against what the manufacture states. If you go this route you’re on your own if there are any damages, this is why many won’t risk violating the warranty by towing against the owners manual recommendation.
Be sure to check out this thread to - Towing or packing a Smart Car on the back of a Class A
* This post was edited 06/23/21 09:38am by Y-Guy *
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
ferndaleflyer
everywhere
Posted: 06/23/21 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Looks like the moderators have taken over this thread. I guess my 7 years and 15,000 mi towing the Smart don't matter. The car has right at 40,000mi on it and only work done on it other than regular maintenance was just put new brakes and tires on it.
Posted: 06/23/21 11:27am Link  |  Quote  |  Print  |  Notify Moderator
The moderators have just expressed an opinion different than your opinion, flyer. That is NOT a takeover.
