RV.Net Open Roads Forum: Tow Vehicles: fuel additives
Search only in Tow Vehicles
 > fuel additives
Page of 8
StirCrazy
Kamloops, BC, Canada
Posted: 06/25/21 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Trackrig wrote:
If you drive in colder areas where they switch to #1 diesel in the winter, then you need it during the winter. To make #1 diesel so it flows better (doesn't turn to slush) in the winter, they take some of the wax out of it which in turn takes the lubricity out of it which in turns means you can loose your expensive injector pump.
When running #1 fuel, use the additive. If all you run is #2 fuel living in a warmer climate, then don't worry about it.
Bill
up here in canada, they put the additives in the fuel to keep it from gelling before it gets to the fuel station, don't they down there?
Aside from fuel system cleaners once and a while, I have run several and all have made no difference, although there is one additive I have been watching the test results for, it was designed or what ever by Pitsburg power and has been doing wondering in the highway tractor world and even thoes people that use it in there personal vehicles are saying they are getting amazing results. it was designed to help keep the system clean, sensors and all that stuff, but they have found there is a boost in gas milage also. when I find where I can buy it with out shipping from the US I am going to try that one.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
ShinerBock
LVTX
Posted: 06/25/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Since 2013 Cummins/RAM have a great filtering system that will help keep the fuel system in good health.
Filters have nothing to do with carbon build-up on injectors from the combustion process or the added soot production from lower cetane fuel. Filters only remove contaminants/water in the fuel. Additives alter how the fuel combusts and the deposits it leaves behind after it combusts. Additives may also add additional lubrication which may or may not be needed based on the quality and type of fuel you are using.
In fact, after doing a quick Google search, your favorite lubricant maker has a short blog article sort of explaining what I have been saying. There is more to it than this, but the basics are there. And as they point out, most refiners only go by federal or state minimum requirements. There is no incentive for them to do more than that.
AMZOIL-What Is Diesel Cetane and Why Does It Matter?
* This post was last edited 06/25/21 01:11pm by ShinerBock *   View edit history
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
Cummins12V98
on the road
Posted: 06/25/21 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Understood, just saying the filtration has made it unusual for injectors to need to be replaced from poor filtration.
Based on that I see no need for fuel conditioner for the injectors.
I don't think lubrication plays kindly with the downstream emissions these days.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Lynnmor
Red Lion
Posted: 06/26/21 01:08am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Cummins12V98 wrote:
Lynnmor wrote:
Cummins12V98 wrote:
Since my 11 and now 15 RAM I have not used anything.
Prior I used a fuel conditioner or two cycle oil.
Ram didn't use the higher pressure CP4 pump till 2018.
Not sure how that relates to what I said?
It doesn't although it shows he's just commenting about something he knows nothing aboot.
If one had the IQ of a turnip, he would understand that the need for lubrication increases as the pressures increase.
JIMNLIN
Oklahoma
Posted: 06/26/21 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Same down here in the states. The fuel brands use different packet additives which are added at the fuel racks when the tanker takes on a load for delivery. See my reply on this thread on 6-24-'21 at 7:59 am about using one fuel supplier vs using different fueling stations which most owners are doing.
WE did have a forum member some years back who drove a fuel tanker and gave us insight on the packets....and sometimes those packets didn't get added.
I get a kick out of filling the fuel filter container on my '03 Dodge/Cummins with Power Service (white jug) when changing fuel filter. Crank it up and its so quiet and a big boost in seat of the pants performance for 5-10 miles.
My '03 Cummins HO just turned over 361k miles. I use mostly Power Service or Howes several times a year in the tank especially when I buy fuel from one source near me most of the time. I like how much quieter/towing performance the Cummins runs... till that tank is diluted with refills.
ShinerBock
LVTX
Posted: 06/26/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
How do the filters remove carbon buildup from the combustion process? [emoticon]
wopachop
Who run bartertown
Posted: 06/26/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
If you dried out a used fuel filter and brushed off the gunk. Then hit it with a propane torch. Wouldnt some of it turn to carbon? I was thinking a fuel filter probably does help to reduce carbon buildup over the years of use.
I wonder if high pollen areas are worse. That is a material that seems like it would burn into charcoal. Dirt maybe no so much. You can put out a fire with dirt. Wouldnt that be nice if dirt and sand produced tiny little microscopic diamonds out the tailpipe?!??
Cummins12V98
on the road
Posted: 06/26/21 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I give! Never said that.
ShinerBock
LVTX
Posted: 06/27/21 10:40am Link  |  Quote  |  Print  |  Notify Moderator
You said "filtration has made it unusual for injectors to need to be replaced from poor filtration. Based on that I see no need for fuel conditioner for the injectors." so how do filters effect excess carbon from the combustion process from using a lower quality fuel or fuel with the minimum cetane rating that is lower than what your engine was optimized to run on? Filters do nothing for this, only additives do.
Posted: 06/27/21 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Cmon shiner. Don’t play 4x4ord with 12V.
You’re a smart enough guy to realize that he’s a smart enough guy to realize that fuel filters don’t control combustion chamber deposits.
There’s a difference between people who may mis speak a bit and those that die on the sword of falsehoods (of which there are plenty on this site, unfortunately).
Page of 8
 > fuel additives
