gpstolpe
Arizona
Trying to register my Fifth Wheel Cougar 2015 in AZ. Cannot figure out how much it will cost. Can't follow their calculation they have.
Near Mammoth, California
I’d ask at an AZ DMV office if I couldn’t do the math. But does it really matter if you will register there anyway?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Cummins12V98
on the road
Contact Department of Licensing, AZ
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
CA Traveler
The Western States
First year vehicle value is 60% of mfg value, reduced by 16.25% each year. Mfg value is in some data base accessed via VIN. Registration for a given year is the yearly value/100*2.89. Ie 2.89 is the vehicle rate per $100 of value.
Therefore a $100,000 2020 used rig would cost: $1734 for 2020 and $1452 for 2021. Rather pricey.
Update 7/13/21 2.89 is the rate for a used vehicle and 2.80 is the rate for a new vehicle. This is per AZDOT on 7/13/21. AZDOT can supply the current year rate and manufactures value for a vehicle given the VIN. Check AZDOT for commercial rates, small utility trailers, reproduced vehicles etc.
last
edited 07/13/21 11:10am by CA Traveler *
View edit history
2014 Grand Cherokee Overland
Bob
AZ truck registration appears more expensive than California. Wow.
tommyznr
NR, WI
That is some nice helpful information CATraveler, kudos to you for throwing a dog a bone.
Tom
2017 GMC Sierra SLT, Max Tow package
2018 Grand Design Reflection 295RL
tommyznr
NR, WI
Lwiddis wrote: I’d ask at an AZ DMV office if I couldn’t do the math. But does it really matter if you will register there anyway?
Do you ever go somewhere to put down that kind of change without knowing at least a ballpark of what it will cost?
C Schomer
Pueblo West, Co.
FYI, when I moved there in 03, I had to take my 5er in for an inspection... IIRC just a VIN inspection. So be prepared. Craig
Me Again
Sunbird(Wa)/snowbird(Az)
I bought an utility trailer to move my Can Am Spyder three wheel motor cycle between Arizona and Washington each spring and fall. $175 for a life time plate!Cars, trucks and RV are really expensive in Arizona however.
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it! RIP DW 07-05-2021
momentum rv
Central Cal.
Lwiddis wrote: AZ truck registration appears more expensive than California. Wow.
My brother just did his 2019 F350 $1700. But that was for 5 years. It was around $700(?) in CA for 1 year.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
