RV.Net Open Roads Forum: Fifth-Wheels: LED Ceiling Lights
 > LED Ceiling Lights
wopachop
Who run bartertown
Posted: 06/24/21 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
For a fire safe temp fix you could poke some holes in aluminum foil. Then try to crimp it around the lens. Might hold itself in place.
CA Traveler
The Western States
Posted: 06/24/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Check carefully as incandescents take 6x+ the power (hence heat) of LEDs. Could also be a wire size issue.
2014 Grand Cherokee Overland
Bob
frankwp
Calgary, AB, Canada
Posted: 06/24/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
This. An LED fixture is not designed for the high temps & heat output of incandescent lamps. Just get new lamps with a warmer color temperature.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
happy2rv
Huntsville, AL, USA
Posted: 06/24/21 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with others regarding swapping incandescent lights in place of LEDs. You would need to carefully assess the wire size, fuse size, and heat resistance.
If you can find a make or model of the fixture you have it might help. LEDs come in a variety of colors and brightness ratings. However, finding something that would adapt to your existing fixture or be a drop in replacement may be more difficult. Dimmers are an option for some, but not all LED fixtures, but it may be difficult to install a dimmer or dimmers depending on how easy it is to access your wiring. You might be able to install dimmers at the wall switch location depending on how many fixtures you have on a switch and what type of switches you have.
In our travel trailer, I moved the over the bed reading lights down below the bedside cabinets and replaced them with different fixtures and dimmers, but these would look quite out of place in the middle of the ceiling.
2018 Forrest River Salem Hemisphere 282RK - 2017 RAM 1500 TV
Previous RVs and TOADS
2004 Fleetwood Bounder 32W on WH W20
2000 Four Winds 5000 21RB
1986 27' Allegro
TOADS
2005 Ford Ranger XLT 2WD
2004 Suzuki Aerio
1988 Chevrolet Sprint
C Schomer
Pueblo West, Co.
Posted: 07/10/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
All of my ceiling fixtures have been fluorescent and I just strip out the fluorescent lites and ballast and put in the LED strips that I like. The biggest problem is shopping for LEDs because so few of the manufacturers give the full specifications and sometimes their light color description is not accurate.
I started using really high lumen LEDs with a high side dimmer so I can have bright light when I want it and dim them when I don’t. I wasn’t sure how well the dimmer would work but I am really happy with it. It merely dims and does not change the light color at all. The older I get the brighter the light is needed! Craig
