RV.Net Open Roads Forum: Im New here, needing help with water damage!
 > Im New here, needing help with water damage!
vianeyz17
Wisconsin
Posted: 06/24/21 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Hello, I recently inherited a 1997 Discover motor home. It is a Fiberglass one and We have ripped out the wall that had water damage and have removed the window. What are my next steps? Fiberglass wall seems good in tact however you can see that the water damage was bad, how can I repair this? do i use a fiberglass primer before installing isolation? Do I use faced insulation or batt? Im assuming ill then apply plywood paneling after?
I did already seal rubber roof with SEALBEST elastomeric roof coating and added tape around the screws on top of rv.
Please looking to get as much tips/ help possible.
* This post was edited 06/24/21 12:20pm by an administrator/moderator *
pianotuna
Regina, SK, Canada
Posted: 06/24/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I would use closed cell spray foam. DO NOT MAKE ANY CUTS TO THE FOAM.
Regards, Don
Near DVNP, California
Posted: 06/24/21 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Have you considered not repairing the water damage? You'll be putting in a bunch of work for an RV (and all its systems) that is 25 years old. If you want a project...go for it. If you want to go camping...
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
vianeyz17
Wisconsin
Posted: 06/24/21 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Are you talking about the spray foam? Not to cut into the foam once its sprayed on?
CA Traveler
The Western States
Posted: 06/24/21 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Remove and reseal everything exterior - lights, windows, etc.
2014 Grand Cherokee Overland
Bob
oldave
Tx
Posted: 06/24/21 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Go on YouTube and look for RV delamination repair You should find a lot of info
pianotuna
Regina, SK, Canada
Posted: 06/24/21 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. If you cut it and it is exposed to moisture in any way the cells will fill and soon mold may rear its ugly head.
Dale.Traveling
Newport News, VA
Posted: 06/25/21 05:52am Link  |  Quote  |  Print  |  Notify Moderator
My one repair I worked from the inside and duplicated the original wall sandwich of materials as best I could with available materials. Fiberglass exterior, 3/16" tempered board, 1" ridged foam insulation and final interior 3/16" tempered board.
Each layer is held in place with two part epoxy. Used a lot of epoxy but I also looking at the epoxy as a water proofing as tempered board and water can be a problem. With a bit of luck the repairs will out last the coach. The hardest part was coming up with a clamping plan to hold everything in place for 24 hours while the epoxy set up.
Pictures of the project. The leak was at the stove vent.
Total Boat 2 Part Epoxy Kit
* This post was edited 06/25/21 05:58am by Dale.Traveling *
2006 Hurricane 31D built on a 2006 Ford F53
