RV.Net Open Roads Forum: Smaller Holding Tanks...What to do when NO hookups??
 > Smaller Holding Tanks...What to do when NO hookups??
JRscooby
Indepmo
Posted: 06/25/21 05:52am Link  |  Quote  |  Print  |  Notify Moderator
I have a Pop Up tent camper. Our black tank is less than 3 gallons on the porta potty. Wife and I, 2 days is easy if we stay out of restaurants. (This assumes no other restroom near. If I can walk a quarter mile thru the day, only dump at end of 3 night stay. Or in the toilet I'm walking to if staying longer.
Gray water. The inside sink is only used for sponge baths (Waterless shampoo and no rinse soap about qt water) and teeth brushing. The drain hose goes into a large laundry soap jug.
Dishes is the big water hog. I set up a sink outside, drain into 7 gallon jug. Use 2 pans. 1 for hot soapy water. Rinse with a small stream of water, and catch it in 2nd dish pan. When done dump the wash water, (Dad kept a bucket, would use that to fill the bowl before number 2. Rest of time just enough water in bowl to cover the seal) Save that rinse water. Next time you do dishes heat a pot of water, (Where does the water that you drain out of pipes to find hot go?) add that and soap to do dishes.
MarkTwain
Northern, Ca. , USA
Posted: 06/25/21 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Baja Man wrote:
So we made compromises....smaller TT, lighter weight, easier to tow, easier to access locations, etc. Smaller, lighter TTs usually equals less CCC which equals smaller holding tanks.
The new to me TT has holding tank capacities as follows:
Fresh: 37ga
B/G: 30ga
Brochure on TT states 50 on fresh, but called Keystone, and per VIN, it is 37.
We mainly camp where there are full hookups.
Some state parks offer water and gray, but no black.
But when we do want to go where there are no hookups, how can we handle the limited tanks?
We travel most of the time with 3 adults......4 on occasion.
Thoughts?
Buy an additional holding tank that you strap to back of your RV.
mockturtle
AZ
Posted: 06/25/21 06:23am Link  |  Quote  |  Print  |  Notify Moderator
As my grey tank usually fills up before my black tank, I often use a plastic dishpan for washing dishes and pour the dishwater down the toilet.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
Trekkar
Michigan
Posted: 06/25/21 06:35am Link  |  Quote  |  Print  |  Notify Moderator
portapotty bags and Poo powder allow for less use of black tank needs.....
2014 Dodge Ram 1500
2021 Salem SFX 167RBK
wing_zealot
East of the Mississippi
Posted: 06/25/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
This is the scoop, if you plan on taking showers every day in the trailer, you might have enough water for two days. If you use the campground facilities (showers and potty) as much as possible you can make it a week easily. We have similar size tanks, we use the campground facilities as much as possible, we regularly camp with electric only; we can go a week and use only half the water in the fresh water tank. Basically, the only water we use is for potty at night, washing dishes, and cooking/coffee.
It's up to you how long its going to last.
Baja Man
Inland Empire, CA
Posted: 06/25/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
bigorange wrote:
Is that 30 each black and gray or combined? If it’s 30 each that’s comparable to what we have now and it’s doable. Gray is always our limiting factor. As others have said just be careful how much goes down the drain. If possible, can wash dishes in a basin and dump that outside if possible or down the toilet if you have separate black and gray. You could also use one of the portable totes for dumping gray assuming the campground has a dump station.
Black: 30
Gray: 30
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
falconbrother
North Carolina
Posted: 06/25/21 08:39am Link  |  Quote  |  Print  |  Notify Moderator
We did a few days of water power only recently. It wasn't too bad. The black tank isn't a problem. The gray tank is where you can get in a bind. Just think of it like glorified tent camping.
Baja Man
Inland Empire, CA
Posted: 06/25/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Anybody use the 6 gal Igloo water containers? How’s this process of storing water in truck bed and transferring to RV tank? Is a bladder preferred? Thought of taking 3-4 in back of truck.
Or a water bladder in rear of truck?
A 20-30 gal water tank would be too large and take much truck bed space…, not as portable as individual water containers.
Thoughts?
I have an F-350 so plenty of payload,
Baja Man
Inland Empire, CA
Posted: 06/25/21 08:47am Link  |  Quote  |  Print  |  Notify Moderator
As far as gray / black water…
Are the portable dumping totes exclusive to its contents ( one for gray and separate one for black) or does one tote handle both?
Storage could be an issue? How do you carry and store when traveling?
JRscooby
Indepmo
Posted: 06/25/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Thoughts?
Back when I first got my camper I needed a way to pour water from a jug into the tank. Bought a plastic funnel, cut so fit tight, cut a notch to bend so the top was flat, welded up the cut, put loops to hang it. Worked great. But a couple years later I had a better idea. If I was going to need to add water, fill the jug a couple days before needed. Then if going to use water outside (most use) pour out of jug.
