RV.Net Open Roads Forum: Fifth-Wheels: Capture plate?
 > Capture plate?
Cummins12V98
on the road
Posted: 06/25/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
ford truck guy wrote:
Cummins12V98 wrote:
schlep1967 wrote:
Cummins12V98 wrote:
No need for a capture plate as long as you visually verify your hitch is PROPERLY latched and there is no space between the pinbox plate and the hitch plate.
To the original poster please disregard the quoted post.
To Cummins12V98 - Giving bad advice is worse than giving no advice. You have no idea what a pullrite superglide hitch is or how it works. Without the capture plate the hitch would not operate properly and damage would occur.
I stand corrected! "Capture plate" to me is the device that stops the RV from dropping if high hitched for example.
Back in the day they used to make a "Bed Saver" It would bolt on the rear of your hitch and "CATCH" the pinbox before it hit the bed if hitched improperly ......
I have not heard about them in years
blue ox
YES, that is what I was thinking, wrong words!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 06/25/21 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry. I was a little harsh with my reply.
Hey no worse than I have given. I appreciate the apology. Like I say words have meaning! I sure don't want to pass along bad info.
Thanks!
hornet28
Muskegon Mi.
Posted: 06/25/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Blue Ox quit building the Bed Saver a number of years ago
cpaulsen
Oregon
Posted: 06/26/21 04:59am Link  |  Quote  |  Print  |  Notify Moderator
You need a captue plate to make the superglide to work right
cpaulsen
MFL
Midwest
Posted: 06/26/21 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
Great post!!
This is not my first forum friend, that has owned his mistake, and announced it on this forum. To me...this reads, a strong man that is confident in who he is!
Jerry
Cummins12V98
on the road
Posted: 06/26/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
Thanks!
Great post!!
Jerry
Thanks Jerry, check is in the mail. [emoticon]
Cummins12V98
on the road
Posted: 06/26/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I would be curious why???
JIMNLIN
Oklahoma
Posted: 06/27/21 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Jaycee85501 wrote:
I am buying a 2007 weekend worrier superlite LS 2805. I am getting a superglide hitch. What capture plate do I need.
Thanks
OP...I'll repost your question and topic.
Anywayz we have Superglide owners who may know how to answer your question.
Looking at PullRites SuperGlide capture plate chart may help you .
However a PullRite hitch dealer or a rv dealer who sells the Superglide can also help. Or a 1-800 or email to numbers on the add in the clicky to PullRite mfg should get a answer.
* This post was edited 07/07/21 05:43pm by an administrator/moderator *
Njmurvin
Simi Valley
Posted: 06/29/21 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
OP, if you live in the So Cal area I have a couple of different capture plates to choose from that I'd be willing to give you. One is a universal mount type that attaches to the pinbox with allen set screws (which I replaced with stainless steel to avoid rust). The other requires that you drill holes in your pinbox and connects with small nuts/bolts. It was fitted to an older Fleetwood Terry 5th wheel trailer. I would need some dimensions of your pinbox's kingpin plate to determine if either is a fit.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
Ron3rd
Upland, CA USA
Posted: 07/06/21 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Depends on your pin box. All brands use various pin boxes
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
 > Capture plate?
