RV.Net Open Roads Forum: Towing: Reese Straight Line Weight Distribution Hitch Question
Search only in Towing
Open Roads Forum  >  Towing
 > Reese Straight Line Weight Distribution Hitch Question
hfrez
Posted: 06/25/21 07:15am Link  |  Quote  |  Print  |  Notify Moderator
I have a Reese Straight Line Weight Distribution Hitch product number 66072 rated for #600. My new trailer requires #900 tongue weight.
Can I Just buy the Trunnion Spring bar rated for #1200 and replace the #600 ones?
Thanks ,
Harold
tlfield
Central NY
Posted: 06/25/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
I did, worked fine.
2020 GMC Sierra 2500HD 4X4
6.6L Gas, Crew cab, 6.5' bed
2015 Jayco Jayflight 29RKS
Reese DualCam
dodge guy
Bartlett IL
Posted: 06/25/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Yes. I think the heads are the same to 1200lbs. IIRC the 1500lb head is different.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
hfrez
Posted: 06/25/21 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your responses. I really appreciate it.
Draggo
Rochester, NY
Posted: 06/25/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
I went from 600 lb bars to 800 lb bars to 1200 lb bars all with the same hitch head and I've been using the 1200 bars for 14 years now so you should be fine to just get new bars.
Mike & Company
2021 GMC Sierra SLE (6.6L V-8, 3.73 rear gear)
2018 Coachmen Freedom Express 279RLDS
Reese W/D & HP DC
QCMan
Independent Republic of Horry
Posted: 06/25/21 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
Another yes here. While you are at it, get the bars with the hook on the end and add the dual cam anti sway section. Been using that since 2004. All parts have a lifetime guarantee.
On edit, I think 1000 pound bars used to be available.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
hfrez
Posted: 06/26/21 05:37am Link  |  Quote  |  Print  |  Notify Moderator
I'm also wondering if any of you found a noticeable difference in using the stronger bars?
hfrez
Posted: 06/28/21 11:02am Link  |  Quote  |  Print  |  Notify Moderator
A little update. I bought the #1200 trunnions and they fit nicely. They are heavier and beefier then the #600 ones. I'm sure that means that anyone could also upgrade to the #800's without a problem. Definitely keep shopping for what you need though, prices ranged from $107 to $265 (for one). I was able to get a great deal on Amazon but etrailer.com was the next best.
I can see how the #1200 Trunnion's will improve the Weight Distribution in a good way.
ktmrfs
Portland, Oregon
Posted: 06/29/21 09:35am Link  |  Quote  |  Print  |  Notify Moderator
if you go to 1200lb or 1400lb bars and have an old system make sure you get the latest and greatest HD snap up brackets with additional gussets. The older gussets with lighter bars are known to end up bending with the heavy bars.
2011 Keystone Outback 295RE
JBarca
Radnor, Ohio, USA
Posted: 07/10/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Thanks ,
Harold
I see your past this now and have the 1,200# WD bars. The Reese HP trunnion bar hitch head, pn 58167, has been revised several times over the years. Reese use to top out at 1,200# in WD mode back in the early 2,000 time frame. Then came heavier trailers and they offered the 1,700# WD bars, then the 1,500# WD bars and they still fit the same 58167 hitch head. They also started adding rating stickers on the side of the head. Like this
Here is the latest all cast steel HD trunnion bar head, 58167 at Etrailer as a stand alone part. Etrailer Reese 58167
The next issue was the hitch shank. The ratings on them changed and the 2" square shank topped out at 1,500#, if you wanted to use the 1,700# bars you have to upgrade to a 2 1/2" shank/receiver. On the 2 1/2" shank, the shank tapers down at the hitch head to fit into the 2" hitch head.
As to the WD bar sizes, the 600# and 800# WD bar look the same as the bar outer size and the trunnion lug head is the same, but the steel temper is different.
The 1,200, 1,500 and the 1,700 WD bar have the same trunnion head, bar size, but the temper of the steel is different.
That 58167 head fits all the newer 600 to 1,700# WD bars. Just heads up incase you get an old Reese WD bar, they use to years back, pre year 2,000 at least have smaller OD lugs on the trunnion bars. While they will fit the new 58167, do not mix a new larger trunnion lug WD bar with an older smaller trunnion lug WD bar. They do not lock up un the hitch head the same.
See here, the 800# bar next to a 1,200# wd bar. The 800# bar on the bottom
As ktmrfs stated, when you go to the 1,200# and up WD bar, the snap up brackets have had issues of bending open in turns in some cases. The issue also has occurred in less frequency on some of the older 1,000# WD bars when they use to offer that size WD bar. You have a few options in this case, if you are on the old style snap up's, bolt them to the frame. Use grade 5 or higher hardware. You can buy the newer reinforced snap up that have welded on gussets on the sides. Like this one, for $72 each. Reese snap up brackets at E trailer
These Reese Trunnion bar head instructions talks about the bolting on the older style WD brackets, page 5 Reese Trunnion bar hitch instructions
As FYI, before those new heavy duty snap up brackets came out, I was already converted to the 1,700# WD hitch system back in 2007 due the 1,600# loaded tongue weight of our current camper in my sig. Back then, the only option we had was bolting on the snap up. I bolted them on and I am still using them after putting on over 35K miles on the trailer later. In my case, I have a channel iron frame and I can use nuts and bolts and not self taping screws. You can see the round heads of the carriage bolts I used in the lower part of the snap up.
If you are running 1,200# and up WD bars, you really want to deal with the snap ups, bolt them on or get the new HD snap ups.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
