RV.Net Open Roads Forum: Truck Campers: Remove/replace onboard generator
 > Remove/replace onboard generator
memilanuk
Dry side of the Cascades
Posted: 06/27/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
deltabravo wrote:
I found a metal supply store that was open today, so I went there and bought some plate aluminum stock and fabbed up some mounting brackets. It's a HUGE PITA to make it work because I didn't want to drill into the base pan of the generator liek Northwood did when they mounted the old skool genny, rather than use the threaded inserts and bolts to mount it.
I should have it installed and running tomorrow
Lookin' forward to the video [emoticon]
deltabravo
Spokane, WA
Posted: 06/27/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
memilanuk wrote:
95F @ 10 o'clock...
Where are you located on the dry side?
memilanuk
Posted: 06/27/21 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
East Wenatchee
devildog1971
Rome
Posted: 07/01/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you find the new 2500lp inverter generator let us know they are really hard to find right now. Cummins told me it will probably be January 2022 before they are plentiful and easy to find.
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2018 Harley Davidson Limited Low
deltabravo
Spokane, WA
Posted: 07/09/21 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
I LOVE THIS GENNY!
With any luck, I will have the next video uploaded tonight.
Here's what I have online so far:
Unboxing
I "popped the hood" to look inside!
imjustdave
Posted: 07/17/21 01:37am Link  |  Quote  |  Print  |  Notify Moderator
Are you making a video on what you needed to change to install this?
I'm considering the same
David
Jayco 2007 30.5 BHS ... Not sure I need the bunks now.
Dodge 2006 3500, Manual, free spin, B&W hitch.
mr_andyj
Georgia
Posted: 07/17/21 10:09am Link  |  Quote  |  Print  |  Notify Moderator
I would leave it as is.
Yes, it is a biggie to have a built-in over a portable, easy to just fire up at will. I would fire mine up and have AC or power whenever I wanted it, even for a rest stop lunch break, no way I would pull out a portable for such short use. Even if portable was permantly mounted and hooked up I would still have to go out and crank it, nahhh.
Live with what you have and then after a few months you will not need to ask for opinions, you will know that you know.
It is propane so that is good and bad, u need to have a bunch of tanks always, but propane burns a lot more clean that gasoline.
The noise level is all your call.
Being on the camper means vibration and the noise is closer, as opposed to a genny sitting on the ground far away, but it is also much more safe and unlikely to grow legs and walk away being mounted.
Kayteg1
California > Nevada
Posted: 07/17/21 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Takes me about 20 seconds to pull the cord to front-mounted Honda and do single pull to start it.
Never had a need to put battery for electric starter on it.
specta
utah
Posted: 07/17/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
I totally agree. It doesn't get any easier.
And once I fire up the AC you literally can't hear the generator running.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
time2roll
Posted: 07/17/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
specta wrote:
Connect the inverter to that switch, fill the space with lithium batteries and max out the roof with solar.
That would be my plan.
675w Solar pictures back up
