RV.Net Open Roads Forum: A/T P tires in front, Highway LT's in back, any problem?
Search only in Towing
Open Roads Forum  >  Towing
 > A/T P tires in front, Highway LT's in back, any problem?
hertfordnc
Hertford, NC
Posted: 06/26/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
My 2002 excursion had an OK set of All terrain tires i was hoping to get another year out of. The fronts were new, rears were in good shape but then i had a blowout.
I want to migrate to Michelin LTX but i can only afford two this month.
Maybe get the other two in the Fall after camping season.
Is there any problem with this other than my truck not looking cool?
Dave & Ellen Silva
Hertford, North Carolina
2002 Excursion
2007 Shamrock Hybrid
1972 Revcon
Monterey, California
Posted: 06/26/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Does your owner’s booklet address this issue?
Posted: 06/26/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
https://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/02hdwog4e.pdf
Page 252 says “no” twice. Page 253 says it two more times.
Terryallan
Foothills NC
Posted: 06/26/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
As long as they are the same circumference. there should be no problem.. The problems come in when all tires aren't the same size
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
hertfordnc
Hertford, NC
Posted: 06/26/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
THanks, that's what i thought. i figure i'll buy the other two by the time i'm due t rotate them.
BobsYourUncle
Calgary Alberta Canada
Posted: 06/26/21 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Different tires have different characteristics of handling properties.
One caution I can offer is to check that out.
Example if one tire has a much more flexible sidewall that the other, it could cause it to handle differently than you are used to.
But basically should be ok.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
jdc1
Rescue, Ca
Posted: 06/26/21 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Since we are not driving high performance cars at LeMans, I'd think you are okay.
BenK
SF BayArea
Posted: 06/26/21 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
think of wearing different brand/size/type/etc shoes. Tennis shoes to hiking boots
Walking around the house would be fine...but...then try running as fast as you can to then 'maneuver' around things.
Those difference will affect during extreme conditions. Like braking & swerving trying to avoid something.
I'd not do it
-Ben Picture of my rig
Cummins12V98
on the road
Posted: 06/26/21 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Stability will be effected. I am betting the Tire store has a credit offer of some sort. Do it right.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JRscooby
Indepmo
Posted: 06/26/21 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Does nobody remember "snow tires"? Back in the day most people, on most vehicles, ran rear tires that did not match the front for about half the year.
(On my pickups, snow tires in winter, then spring I would name them "Mud Grips")
As for different size F/R. 2 wheel drive, this is not a issue. 4 Wheel drive, can be a problem unless on surfaces you need 4 WD, and tires can slip
