RV.Net Open Roads Forum: General RVing Issues: Electric bikes !!
 > Electric bikes !!
Page of 10
GMH
Canada
Posted: 07/27/21 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
I bought this folding CCM carrier for our regular bikes. I didn’t trust it for our e-bikes so I replaced all the folding parts with heavy wall tubing. It is rock solid now.
Disclaimer: You may need to address Plate and lighting issues with this setup!
* This post was edited 07/30/21 08:49am by GMH *
CavemanCharlie
Storden,MN
Posted: 07/28/21 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
That would get you a ticket around here. First, and most importantly of all, you are blocking the turn signals !! Second, you are blocking the headlights. Third, you are blocking the front license plate. Forth, you could be interfering with the operation of the air bag system (might not get a ticket for that part though) .
GMH
Canada
Posted: 07/30/21 08:47am Link  |  Quote  |  Print  |  Notify Moderator
I’m aware! I don’t travel at night and the signal lights are still visible…somewhat. The bikes are the last thing to get loaded before I leave the city and I drive extremely defensively in traffic, so I am more worried about a ticket than an accident. If I do get one I will have to re-think things. I have thought of relocating the plate. I added a warning to my post for anyone who may consider this option.
* This post was edited 07/30/21 08:53am by GMH *
ktmrfs
Portland, Oregon
Posted: 07/30/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
In oregon your ok for the headlights as long as your driving in the daytime. nighttime would get you into trouble. I looked at this option for my motorcycle on a front rack. Headlights and turn signals would have been ok, but the top of the bike interfered to much with my forward vision so I dropped the idea. My truck also has turn signals visible on the rear view mirrors from the front or back, not sure if that would suffice for turn signal visibility.
2011 Keystone Outback 295RE
way2roll
Wilmington NC
Posted: 07/30/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Aren't headlights required in rain and fog?
ktmrfs
Portland, Oregon
Posted: 07/30/21 11:31am Link  |  Quote  |  Print  |  Notify Moderator
depends on the state. Not required in oregon. headlights required to be on from 1/2 hour before sunset to 1/2 hour after sunrise and when you can't see cars 1000ft in front of you. So you could be required to use headlights during heavy fog or heavy rain.
On two of my cars, headlights do come on automatically when the wipers are on or in intermittent mode.
Lightning55
Pleasanton, CA
Posted: 08/05/21 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Just a little reminder to electric bike riders: Be careful on these things! While camping last weekend, I went for a ride with my grand daughter and crashed.
Riding on an asphalt path on a hillside, my front wheel drifted off the edge of the pavement and hit the dirt. I lost traction and went flying. Lucky I didn't break anything but got banged up. At 74 yrs old, I don't recover as fast and didn't walk too well for a couple of days. It was my own fault. I was going faster than I should have and didn't have the ability to control this nearly 100 lbs bike when I lost traction. I was lucky I'm not in the hospital right now.
ktmrfs
Portland, Oregon
Posted: 08/05/21 10:39am Link  |  Quote  |  Print  |  Notify Moderator
yes, on the e bikes it's easy to go faster than you would on a regular bike. Not sure about a 100lb ebike, ours are a typical "heavy" e bike at 52lbs each. And have hydraulic disk brakes. those hydraulic disks work much faster and more controllable than the mechanical disk brakes my regular bike had.
Lightning55
Pleasanton, CA
Posted: 08/05/21 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
ktmrfs - I guess I was exaggerating a bit at 100lbs, it's actually 65 lbs. When I crashed, I was on my back under the bike and it felt like over 100 lbs. trying to get out from under it! I think trying to hold on, I actually hit the twist throttle and launched it as I went down. Not a fun ride.
JRscooby
Indepmo
Posted: 08/05/21 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Back when I was about 10, kids my age in the neighborhood where getting new bikes. Dad decided to teach me to ride his motorcycle around the big yard. A better thrill than new bike.
1 thing he drilled into my head; "It will not work if you are going to hit something, but if you see you are going to fall, open the throttle. Most times, power is more likely to pull you up than brakes, you get a 2nd chance to control it. And if you don't pull it out, you go down in glory!"
Page of 10
 > Electric bikes !!
