RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: Wood fired pizza oven
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > Wood fired pizza oven
scubastu
Lethbridge, Alberta
Posted: 06/27/21 10:03am Link  |  Quote  |  Print  |  Notify Moderator
I just purchased a Ooni Fyra wood pellet fired oven. Just wondering if anyone else has similar on the RV?
Thanks,
Monterey, California
Posted: 06/27/21 10:14am Link  |  Quote  |  Print  |  Notify Moderator
That would be fun to try out but all camping wood fires are banned in California, or will be soon.
stickdog
Somewhere, USA
Posted: 06/27/21 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
No. Since you asked.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
wopachop
Who run bartertown
Posted: 06/27/21 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Seen a couple out in the sand dunes. Pizzas come out looking great.
magnusfide
On the Road Again and Again and Again...
Posted: 06/28/21 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
If the grands are craving pizza we'll make some in a cast iron skillet on the campfire. We already have the skillet and aluminum foil. You can see the method in this video.
Campfire Pizza
"The only time you should fear cast iron is if your wife is fixin' to hit you with it."-Kent Rollins
First law of science: don't spit into the wind.
Bacon is the duct tape of the kitchen.
Magnus
wopachop
Who run bartertown
Posted: 06/28/21 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Nice pizza video!! Was thinking 15-20 mins at that heat is gonna burn the bottom. Might be better to set the dough down on the hot pan. Give it a couple mins. Then flip it over and get toppings on super fast and cover. Ive made a lot of pizza on different surfaces and sometimes its hard to cook the dough all the way through before one side starts to burn. I think most charcoal grill pizzas use this method. Precook one side and try to be light on the toppings.
Ive been making a lot of flatbread pizzas lately. Love that soft fresh bread!! Not as good as pizza dough but much quicker and easier.
magnusfide
Posted: 06/28/21 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
I think if the vid cook had raised the pan off the fire more it wouldn’t have burned. Sometimes we do one in a Dutch oven with coals on the lid and bottom using the baking ratio.
wopachop
Who run bartertown
Posted: 06/28/21 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah or start the process not too hot. If the cast iron is 450+ the dough only needs minutes. Neapolitan style.
Ever see the alton brown pancake episode? He uses water drops to determine the griddle temp. Around 350f water will bubble and shake around.
I use that method all the time to check pan temp. If the water doesnt bubble you're under 350. If the water goes insane you're well above 350f.
propchef
NORCAL
Posted: 06/29/21 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Fires are still allowed in campgrounds at existing fire rings and in grill/bbqs that sit off the ground. Backcountry fire permits have all been canceled.
These ovens are great and fix the issues found when trying to cook pizza on the grill, the problem of getting enough top heat (hence the flipping trick).
Let us know how you like it. I've been wanting one of these.
scubastu
Lethbridge, Alberta
Posted: 08/14/21 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Onni oven working great. Made 7 pizza so far, each one better then the last.
Oven deck reaches up to 1000oF, pizza done in one to two minutes.
