RV.Net Open Roads Forum: Tow Vehicles: Do I have have enough Truck?
Search only in Tow Vehicles
 > Do I have have enough Truck?
blt2ski
Kirkland, Wa
Posted: 06/27/21 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
The springs I put on did not ride any rougher than stock springs. Added maybe an inch of rear height. I had already tweaked the front torsion bars a bit, I also had the snow plow front bars factory ordered. That truck rode no rougher softer than the 05 dually I replaced it with.
A spring shop should be able to make them hold a load, yet ride nice unloaded too!
Yes there is a way to load pics......I need to look up and get a link.....not real good myself at this.
Marty
blt2ski
Kirkland, Wa
Posted: 06/27/21 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
http://photoposting.is-great.net/?i=2
Try that link, I hope I did it correct. Works simple enough to post pics.
On an edit, today's project, getting old truck ready to go to wrecking recycle yard.
If your on an actual computer you can go back and forth. Or you may want the RV.net post up on one screen, the photo hoster on another screen, copy and pasting can be easier that way.
Marty
* This post was edited 06/27/21 08:29pm by blt2ski *
2014 Chevy 1500 Dual cab 4x4
BenK
SF BayArea
Posted: 06/27/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
This is the brake chart from my 1996 Suburban shop manual
[image]Click For Full-Size Image.
You can look up the RPO code on the glove box RPO label
Or, measure your rear drum brake shoe width. Mine is the JB8. Most 3/4 ton Sub’s have the JD7 and why tongue-n-cheek refer to mine as a K3500
Link to an old, old thread here and is where found that brake RPO code image
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25116103/print/true.cfm
-Ben Picture of my rig
Second Chance
Wherever...
Posted: 06/27/21 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
b1jetmech wrote:
Second Chance wrote:
Loaded, the pin weight for that trailer is more likely to be in the 2,500 - 2,800 lb. range. I would suggest weighing the truck (full tanks and all occupants), add 150 lbs. for a hitch over the rear axle, and see what you have left over on the rear axle and tire ratings.
Rob
Hi Rob,
Yeah, I need to find a DOT scale to weight the truck and weigh it again with the trailer and all occupants. I do have a feeling it will be well over the payload capacity. We'll see.
I would suggest a CAT scale at the nearest truck stop. The DOT boys will usually give someone in a non-commercial vehicle some dirty looks if you pull in there (unless you know someone, of course). In some places, the state weigh stations leave the scales on when they're closed. If you can see the read-out through the windows, you can just add your own weight back in.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Posted: 06/27/21 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
I’ll suggest if you claim to be adept at Cummins conversions and whatever else you said, and are asking the question, then you already know the answer. And if you don’t, then the answer is, no, you need more/newer truck.
There are so many more things in the equation than just the power train. Namely, it’s a 25 year old truck.
Again if you don’t understand, then put the diesel conversion money towards a newer/ more capable truck.
PS I think gmt 400s are some of the best tucks made, so my statement isn’t about any inherent flaws in the design of the truck.
2017 Heartland Torque T29
Posted: 06/27/21 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Especially if you’re actually hung up on “rated” payload…you don’t understand vehicles very well.
ferndaleflyer
everywhere
Posted: 06/27/21 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'll not get into all the details above BUT----You never have enough truck!!!!!
Second Chance
Wherever...
Posted: 06/28/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
b1jetmech wrote:
Is there a way to post pictures directly from the computer? I don't have a picture host anymore. Would like to upload some pics.
RVNet photo posting
Rob
JIMNLIN
Oklahoma
Posted: 06/28/21 07:43am Link  |  Quote  |  Print  |  Notify Moderator
One of my previous trucks was a '92 2500 4wd gmc 5.7 engine 400 tranny 4.10 gears. I ran that truck to 262k miles before selling it to a local brick layer.
Just a word of caution.
Your trucks 6089 rawr number can be the lessor of the tire/wheel/rear spring pack. Generally our older trucks those LT235/85-16 or LT245/75-16 E rated tires had 3042 lbs capacity were the weak link. Upgrade the tires.... the OEM wheels may also need upgraded depending on their load rating. Most OEM steel wheels back then were load stamped some where on the wheel (front/rear side or in the valley).
Rear air bags is another option for carrying more load and leveling the load. The springs on a truck that old probably sag some do to use and age.
Agree with separate front and rear axle weights. Everyone with a truck should know this when towing or hauling heavy.
Posted: 06/28/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Everyone getting hung up in the rvnet fodder of "ratings."
OP what is your plan here? You got a pristine low mile grampa truck that you want to hot rod into a towing machine?
You get a free engine and Allison and it's taking up space in your shop?
You're bored and want a "project?" "Projects" don't usually make good tow rigs.
Have you added up what this will cost you in just parts, provided the truck is already cherry/perfect and you will be doing all the work yourself?
Have you looked at the truck market for buying and selling? If your truck is in great shape, it will fetch more $ now, likely than ever in the past and maybe the future.
Are you rebuilding the Cummins and the Alli, or just tossing junkyard drivetrain in it?
Have you considered everything else that will or may be needed? Cutting/fabbing core support, relocating hood latch, moving/fabbing trans cross member(s), adapting or purchasing new T case....just off the top of my head.
And if you get the whole drivetrain swapped, everything working, the least of your concerns is brakes and springs. On a cost and difficulty scale, the brakes and suspension is a 2 out of 10 compared to the swap, which is about a 9.9 out of 10.
Not trying to pee on your parade, but this doesn't sound like the making of a great tow rig, this sounds like the making of an expensive pain in the ....
Here's a quote from a guy who put a 12V into a GMT 400 burb, and he used the original trans and T-case.
"With the engine I think I am about $7000.
Between the flexplate, the trans adapter and the controller, $2000 of that was just to keep the 4L80E (ouch) but I didn't want to adapt a Dodge trans in it to the transfer case and then figure out the speed sensors, etc."
This is a stock used, basically "junkyard" 12V mated to the anemic (for a diesel) 4L80 trans.
If you are doing it "right", I'd guess about $15k minimum in parts and if you're successful in the end, you'll have a truck that is worth no more, really, than as it sits now.
