RV.Net Open Roads Forum: Tech Issues: Filling the water tank at home
 > Filling the water tank at home
Page of 5
valhalla360
No paticular place.
Posted: 06/28/21 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
wildtoad wrote:
agesilaus wrote:
Use a in line filter on the fill hose. I assume this lake water has been checked by the county health dept. It seems to be an unusual water source.
Many people who live on lakes pull water from them for both irrigation and household use. To your point, having the water tested periodically is a good idea. The same holds true for the millions of households the get their drinking water from a well. One should always use a filter at CG’s regardless of the water source. Never know when a water line may break.
Well water is wildly different from lake water.
The well actually functions as a filtration system. Any water that makes it to the well pump has filtered thru 30 or more feet of soil. There will typically be a test when the well is first put in (if it filters thru a layer of heavy metal that ain't good)...but after that, there is little benefit to further testing.
Pulling from a lake, guess where deer and bear poop washes after a rain? Plus you have fish, snails and all kinds of microbes. The water quality can change drastically over the course of the year. After a storm or spring snow melt can introduce significant amounts of contaminants. Hot weather can grow algae and other microbes.
If the water is actually safe, a simple sediment filter on the fill hose will do the trick for any residual sediment.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
valhalla360
No paticular place.
Posted: 06/28/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Mike134 wrote:
I remember my first trip to the boundary waters canoe area in Minnesota.
Us city kids were stunned when the outfitter told us to drink the lake water no filter needed.
I must say we had no issues.
Works great...until it doesn't.
stevenal
Newport, OR, USA
Posted: 06/28/21 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
And I recall portaging around the beaver dams there as a youth. Ever here of beaver fever (giardia)? We also drank the water; after treating it.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
agesilaus
North Florida
Posted: 06/28/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Didn't Minnesota have a big outbreak ofCryptosporosis?
When consumed in contaminated water, the microscopic parasite Cryptosporidium can cause symptoms of stomach cramps, diarrhea and fever. Now, researchers reporting in the ACS journal Environmental Science & Technology have detected evidence of the parasite in about 40 percent of surveyed wells in public water systems in Minnesota -- even wells not influenced by surface water. The team emphasizes that they don't know whether the parasite levels are high enough to actually cause health concerns.
or Giardia:
Surface Water. Cysts have been found all months of the year in surface waters from the Arctic to thetropics in even the most pristine of surface waters. Occasionally, seasonal variations are reported. Cyst levelsare generally higher in rivers or streams influenced by agricultural (e.g., cattle or dairy farming) or residential(e.g., sewage discharges) activities. Cysts occur in surface waters throughout the year. In North America, levelsare generally higher in the late summer to early winter. Generally, no relationship is seen between cyst levelsand bacterial indicators of water contamination. In the United States, levels of Giardia in water are somewhatlower than Cryptosporidium; in Canada, surveys have found higher levels of Giardia than Cryptosporidium.
These are the reason hikers care Life Straws or other water treatment devices with them. Even the old iodine pills.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
MNRon
Tennessee
Posted: 06/28/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Used to drink water straight from lakes in BWCA in late ‘70’s (took from below surface)…but by early 2000’s it was recommended to filter it before use. Backpack filters are a pain to use, but we never got sick…which would be more of a pain.
I too am a little surprised about lake source for drinking water
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
Mike134
Elgin, IL
Posted: 06/28/21 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Are you related to Glum from the book Gulliver's Travels? Asking for a friend.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
swimmer_spe
Sudbury, Ontario, Canada
Posted: 06/28/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Then you won't want to learn about where and how NYC gets it's water.
Gjac
Milford, CT
Posted: 06/28/21 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
When I first bought the MH I stayed a month at Lake of the Woods in Ontario which draws its water from the bottom of the lake and was safe to drink. I had a canister filter and noticed after several weeks the water pressure was low. When I unscrewed the canister to check the filter it was loaded with a clear jelly like substance that was blocking the flow of water. I followed the plastic tube out to about 40 ft of water and dove down with my mask and saw a filter on the end of it but this stuff was still getting through. So I am glad I had the filter in the MH.
MNRon
Tennessee
Posted: 06/28/21 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
LOTS (most?) cities get water from lakes and rivers, but pretty sure it’s treated before it shows up in your tap. Pulling drinking water directly from surface sources is what surprised me…
swimmer_spe
Posted: 06/28/21 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
NYC does not treat it's water. Read up on it and it will impress and surprise you.
My lake water is treated with 2 filters and a UV filter.
Page of 5
