RV.Net Open Roads Forum: Tech Issues: Filling the water tank at home
 > Filling the water tank at home
Page of 5
agesilaus
North Florida
Posted: 06/28/21 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
NYC does not treat it's water. Read up on it and it will impress and surprise you.
No but it is frequently tested for 126 priority pollutants and scores of others continuously. Include E.Coli, Viruses, BOD and other biological testing. Unless the EPA has upped the test count.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
swimmer_spe
Sudbury, Ontario, Canada
Posted: 06/28/21 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Point is that if NYC is safe to draw from a lake, without any filtration, my home is safe as well. I am taking precautions to ensure that I don't have to worry about my water.
MNRon
Tennessee
Posted: 06/28/21 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
Swimmer spe - I’d consider UV disinfecting and adding fluoride “treating” the water before it shows up in your tap…
https://en.m.wikipedia.org/wiki/New_York_City_water_supply_system
With that said, we’ve kind of taken this thread way off topic. To get back to OP, I always use an in-line filter for any water going into my 5er tank. Additionally, when we used to have a private well, I used to add a small amount of chlorine to my tank from home if it would be sitting more than a few weeks.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
wildtoad
Blythewood, SC
Posted: 06/29/21 05:01am Link  |  Quote  |  Print  |  Notify Moderator
I agree there are differences between a lake as a source, and ground water. Not my point. I have had several wells and they all have had issues overtime with various contaminants. Some started sucking sand which is really a pain unless you have a sediment filter to catch it. I have been to state parks where the water line breaks and “stuff” enters the system. When a city water main breaks one usually receives a boil water message. How many sedimentary contaminants entered the system? My main point is regardless of water source a filter is a good idea.
agesilaus wrote:
wildtoad wrote:
agesilaus wrote:
Use a in line filter on the fill hose. I assume this lake water has been checked by the county health dept. It seems to be an unusual water source.
Many people who live on lakes pull water from them for both irrigation and household use. To your point, having the water tested periodically is a good idea. The same holds true for the millions of households the get their drinking water from a well. One should always use a filter at CG’s regardless of the water source. Never know when a water line may break.
Well no, it is by no means the same as a well. For background, I wqent to Environmental Engineering school, was the Technical Director of a environmental laboratory. And we underwent frequent inspections by both the state DEP and the USEPA.
A well is not so easily contaminated, a lake on the other hand is open and who knows what is going into the water. Giardia and Cryptosporidium are frequently found in open water, lakes and rivers. Depending on the state DEP and laws you probably are required to have the local county come by and inspect the water source as well as test the water. And to get a permit. Frankly I'm just not familiar in detail to what inspections and what frequency those inspections would be because I've never seen an open lake used as a water source for a home. But on the other hand if the home owner is happy then who am I to complain?
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
agesilaus
North Florida
Posted: 06/29/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Is New York City water treated?
While NYC's water is unfiltered, it does get treated with chlorine to kill germs, fluoride to prevent cavities, orthophosphate to inhibit lead contamination from pipes, and sodium hydroxide to lessen acidity.Jul 29, 2011
So 'untreated' is an urban myth
swimmer_spe
Posted: 06/29/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
My home has a UV light.
mr_andyj
Georgia
Posted: 06/29/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
test your city water while you are at it. Mine has up to 500 toxins in it.
Boon Docker
Posted: 06/29/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Wow, only 500!
Posted: 06/29/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Mike134 wrote:
I remember my first trip to the boundary waters canoe area in Minnesota.
Us city kids were stunned when the outfitter told us to drink the lake water no filter needed.
I must say we had no issues.
Boundary Waters! Good times and even better fishing!
It's ok Mike, people are just softer than they used to be. Even alot of the old ones who used to be tough...
2017 Heartland Torque T29
Posted: 06/29/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the entertainment swimmerspee.
To answer your question, do the math. How much water you use at the house, how much sediment. Scale that to how much you're putting in the camper, roughly Therein lies your answer.
Page of 5
