RV.Net Open Roads Forum: Electric over hydraulic - anyone using them ?
 > Electric over hydraulic - anyone using them ?
theoldwizard1
SE MI
Posted: 06/28/21 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
What is good and what is bad about them ?
valhalla360
No paticular place.
Posted: 06/28/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Electric or hydraulic...what?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
lenr
Indianapolis, IN
Posted: 06/28/21 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
In RVs electric over hydraulic usually means hydraulic disk brakes on the trailer controlled by the brake electric wire from the tow vehicle. OP, is that what your asking? There are often some kinks to work out, but once things are smoothed out disk brakes are very strong.
n0arp
FT
Posted: 06/28/21 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
We have Titan EoH disc brakes on our fifth wheel. Highly recommend them.
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
Gdetrailer
PA
Posted: 06/28/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
These..
Which is a disk brake system.
The problem with disk brakes on a trailer is getting the hydraulic pressure from the vehicle to the trailers brakes..
To get around the need for hydraulic hoses that would have to connect from the tow vehicle to the trailer there is a Master Cylinder/reservoir/electric pump that is mounted on the trailer.
Looks like this..
The Master cylinder/reservoir/electric pump is now controlled via your vehicles electric brake controller..
Hence, the name "Electric over Hydraulic" (AKA EOH).
Reason for disk brakes, improved braking with less fade.
Downsides is mainly cost, parts alone in kit form is running around $1K and if you had to pay for labor to retrofit you could easily add $1K-$2K to the price tag..
Secondary downside is not all brake controllers play well with the EOH controller and may require considerable tweeking and adjusting to get it to work correctly.
Additionally you now have another hydraulic system that will need to be checked and monitored for fluid levels and contamination and you now have a lot of non standard hydraulic hoses, lines and parts that are not "off the shelf" readily available easy to find parts.
To me, it makes a simple braking system overly complex and expensive and personally most of the weak braking issues with drum brakes people have can be solved by simply upsizing the brake wires on the RV. Most manufacturers tend to skimp on the wire size they use for the drum brakes which causes as much as 20% less braking power..
I would try replacing the electric brake wiring with a much heavier ga wire at a fraction of the cost of EOH as the first line of defense..
Myself, running two pairs of 10 ga wire to replace the one pair of 14 ga factory wire was a huge noticeable improvement in my brakes.
n0arp
FT
Posted: 06/28/21 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
I top off fluid once a year, and have never had any contamination issues. I flushed the system after four or five years, when doing work on a caliper (more on that below). That's not much additional maintenance.
The hoses and lines are all standard diameters and fittings, easy to source at almost any automotive store. The only variation is length, and if you are in a pinch you can go in with a longer hose or just cap off that axle and limp on.
The brakes themselves are all based off of old GM designs (https://www.kodiaktrailer.com/wp-content/uploads/2015/08/KODIAK-CALIPER-TO-GM-REFERENCE-741-KB-10.pdf), and nearly all parts you would need available at any auto parts store. The only notable variations would be the coating, and of course the controller/pump and hub adapter. I had a caliper seal start leaking on the road, and rebuilt it with parts from the local NAPA.
I'd take EoH discs any day over drums, especially if hauling in the mountains. I wouldn't let any preconceived notions like those steer me away.
Gdetrailer
PA
Posted: 06/28/21 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
The brakes themselves are all based off of old GM designs (https://www.kodiaktrailer.com/wp-content/uploads/2015/08/KODIAK-CALIPER-TO-GM-REFERENCE-741-KB-10.pdf), and nearly all parts you would need available at any auto parts store. The only notable variations would be the coating, and of course the controller/pump and hub adapter. I had a caliper seal fail on the road, and rebuilt it with parts from the local NAPA.
You won't find any of those parts in any of my local autoparts stores, they barely can find the correct auto parts for vehicles let alone size up hydraulic hoses. Those brake hoses, rotors, calipers and brake pads are not standard for any vehicle and without a vehicle brand name, model name and yr they cannot look up any of those parts in their computer systems.. And yes, I am talking about Autozone and such places.
NAPA if you are lucky enough to have a 50yr old NAPA store may still have old dusty paper books, they may be able to find them but you will pay the NAPA premium price tag for them.
Contrast that to drum brakes where I can find those in stock at Tractor Supply and most any trailer dealer that handles horse trailers, flatbed trailers, enclosed trailers and even have a choice of two different custom trailer builders near me that even have brand new complete axle assemblies in stock.
Additionally, there is zero redundancy with EOH systems, hydraulic line damage, breakage, rust through or failed pump will result in zero brakes on the trailer working..
At least with electric drum brakes if one of the wires to one of the drums break you only lose that drum.. And yes, I have had that happen when I snagged something laying on the road.. At least I had three other brakes that continued to work.
n0arp
FT
Posted: 06/28/21 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
O'Reilly (just one example) stocks generic "BrakeBest" hoses that are universal fitment. The one closest to me in a small town in NW Indiana, shows that they have 71 different ones in stock for in-store pickup today. Go to the store and lay eyes on them, and you'll find what you need. I checked out the selection when buying spare parts to carry in my toolbox a while back. Plenty of valid options as I was able to assemble a kit from what they had on hand.
I found all new seals for one of my calipers at a NAPA in West Yellowstone, MT.
I completely agree with you on redundancy. If you lose the EoH controller/pump or a line or even a seal, you will lose your brakes. Fortunately those failures are rare, and the increased stopping power and control overshadows the risks. I experienced one failure in five years and 20-25K miles, which is probably one too many. Luckily, I noticed it during a routine brake test at slow speed after hooking up, and (I believe) it was due to dirt making its way into the crevice behind the pad due to extended use on dirt/unimproved roads and lands.
There are ways to mitigate most of those issues and perform most roadside repairs. I opted to carry a handful of spare parts to address any issue short of a complete pump or hub failure, after experiencing the one. Again, I would never consider going back to drum brakes on a 16+K trailer and consider it well worth the risk, though there is substantial room for improvement in the market.
Gdetrailer
PA
Posted: 06/28/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
I completely agree with you on redundancy. If you lose the EoH controller/pump or a line or even a seal, you will lose your brakes. Fortunately those failures are rare, and the increased stopping power and control more or less justifies it for me. I experienced one failure in five years and 20-25K miles, which is probably one too many. Luckily, I noticed it during a routine brake test at slow speed after hooking up, and (I believe) it was due to dirt making its way into the crevice behind the pad due to extended use on dirt/unimproved roads and lands.
There are ways to mitigate most of those issues and perform roadside repairs (anything excluding complete controller/pump failure). Again, I would never consider going back to drum brakes on a 16+K trailer. I opted to carry a handful of spare parts to address any issue short of a complete pump or hub failure.
No Oriely around me, have a couple of NAPA stores but I could simply buy a new trailer for the prices they charge.. Last time I bought anything at a NAPA was a couple of incandescent taillight bulbs, yeah $5 later for a pack of 2, could have bought those at WM for $1.99 but it would have cost $3 in fuel to run to WM..
The box autoparts stores near to me all rely on their computer systems, they have zero ways to simply browse for say brake hose..
As far as drums goes, I also have a 10K GVW flatbed trailer which has drums, it has 5,200 lb axles, I have had loads in excess of 12K lbs on that trailer and have never had issues with not enough brakes or brake fade. Last summer I moved 2 cords of green Oak (nearly 8K lbs), that was eight 40" across "rounds" that were 20" tall plus my tractor with FEL and backhoe (4K lbs)Tractor FEL is rated 980 lbs lift and the FEL was barely able to lift those rounds. Trailer weighs empty 2700 lbs (14K+ lbs load and trailer combined!) and still only had my brake controller set to 5.5 out of 10 for gain and never felt like the trailer brakes were not working or effective. Have to take a couple of massive steep hills for some of the fire wood loads I haul on a regular basis.
So, yeah, I have experienced loads darn near 16K lbs on a trailer with drum brakes that are technically only good for 10.5K lbs..
Good quality wiring to the brakes also makes a difference, wouldn't want to try that with 14 ga wiring..
If one has drums and is looking for better braking, try running heavier wire first, much cheaper and will drastically improve braking performance.
mr_andyj
Georgia
Posted: 06/29/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
As you can see hydro brakes are a major install, cost, complexity etc...
How big of a trailer are you towing down mountains all the time?
Do you own a diesel truck? Spend your money on exhaust brakes instead.
Have you or can you considered/add bigger drums? if they will fit in the wheels, or put on bigger wheels so you can install bigger drums.
Yes, as in your car, disc should be superior, but only if necessary....
