RV.Net Open Roads Forum: Tech Issues: winegard 2.0 connect
 > winegard 2.0 connect
allbrandauto
maryland
Posted: 06/29/21 06:13am Link  |  Quote  |  Print  |  Notify Moderator
when i am at a campground with a weak cell phone signal will a winegard 2.0 connect help with cell phone and internet
Gdetrailer
PA
Posted: 06/29/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
No one can say for sure, all you can do is spend the money and see if it helps.
It may help or it may not, all depends on the noise in the little bit of signal you have to work with.. Amplifiers amplify not only the wanted signal but any noise and interference around you plus adds the noise generated by the amp into the output..
Garbage in + amp = amplified garbage out.
JKJavelin
Milwaukee, WI
Posted: 06/29/21 06:34am Link  |  Quote  |  Print  |  Notify Moderator
We have the Connect2.0 with 4GLTE and it usually improves the campground wifi but not phone service. It can be a finicky device at times and the 4G from Winegard is expensive.
T-Mobile now has a Winegard compatible 4G plan ($50/month for 100 gigs) and I just got the sim card yesterday. We may not have to deal with campground wifi at all anymore. We'll see.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
2021- 110 Nights
Dutch_12078
Winters south, summers north
Posted: 06/29/21 06:36am Link  |  Quote  |  Print  |  Notify Moderator
I've found we're getting much better cell signals using a directional MIMO antenna pair than we did with a cell booster/amplifier.
Dutch
2001 GBM Landau 34' Class A
LouLawrence
Traveling the US!
Posted: 06/29/21 07:15am Link  |  Quote  |  Print  |  Notify Moderator
The Connect is not designed to help your cell phone service in any way. It is designed for Wi-Fi and cellular data plans. Improving campground Wi-Fi signals does not mean it will improve service. When campground Wi-Fi service is poor it will remain poor no matter how close you are to the router. If the campground happens to have good service but you are too far away from the router for a good connection, then the stronger signal can help.
