RV.Net Open Roads Forum: Class C Motorhomes: Onan 4K generator
 > Onan 4K generator
dfletcherljs
Ohio
Posted: 06/29/21 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
I recently had a fuel problem with my generator, put an Edelbrock fuelpump in and ran like a dream, after an hour it died and would not start again, wont turn over. I checked breaker and had power to the switch on the generator but not starting. Could it be an oil sensor?
rjstractor
Maple Valley, WA
Posted: 06/29/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Won't turn over or won't run? If it won't turn over at all, either it's a starter/electrical problem or it's completely seized.
eHoefler
ozark mountains
Posted: 06/30/21 05:54am Link  |  Quote  |  Print  |  Notify Moderator
Pull the spark plug and try to crank it. Your fuel pump may be too high in pressure and overrun the float in the carburetor, causing it to flood out and fill the cylinder with gas and hydro-locking it.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
ItsyRV
Lost on the Blue Ridge Parkway
Posted: 06/30/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
I know you probably already checked this, but, make sure the fuel level in your tank is enough to reach the pickup tube for the generator.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
Gjac
Milford, CT
Posted: 06/30/21 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Are you getting 12v to the genset itself from your battery cables? Also there are usually three starting switches on on the dash one with all your other 12v switches usually above stove and one on the genset itself. Do you get no cranking with all three switches? If all three switches produce no cranking check your breakers on the genset and check to see if there is an inline fuse maybe near the battery.
* This post was edited 07/02/21 06:25am by Gjac *
jdc1
Rescue, Ca
Posted: 06/30/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
You need a low pressure fuel pump. 2.5 to 4 psi. Most auto parts carry them for less than $30
Posted: 06/30/21 10:19am Link  |  Quote  |  Print  |  Notify Moderator
That's what the little Edelbrock /Mr. Gasket pumps are. Although they are on the high side IIRC at 4psi maybe a bit more although likely lower if not installed in an ideal location.
OP gotta give more breadcrumbs though or the diagnosis suggestions will be random.
2017 Heartland Torque T29
whemme
Spencer, IA
Posted: 06/30/21 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
That problem will not cause the starter motor to fail to crank. With not getting any fuel the generator should crank but just won’t start.
2002 Born Free 26' RSB Motorcoach
2005 Chevrolet Malibu LS Toad
Posted: 07/01/21 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Gotta love the “I need help but I’m not checking back in “ folks…
 > Onan 4K generator
