RV.Net Open Roads Forum: Class A Motorhomes: Aftermarket wheel up grade
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Aftermarket wheel up grade
Pctek5000
Posted: 06/29/21 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have 97 F53 I'd like to do away with the 16" wheel & move up to a 19.5 wheel has anybody done this & where did they find there new wheels at.
Thank you in Advance
Monterey, California
Posted: 06/29/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Check the max wheel weight carefully for whatever you choose.
* This post was edited 06/29/21 06:53pm by Lwiddis *
Dutch_12078
Winters south, summers north
Posted: 06/29/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Rickson Wheels has the conversion wheels for $261.87 each:
19.5” WHEEL & TIRE UPGRADES FOR MOTORHOMES ON 1997-Back FORD F-53 CHASSIS
Dutch
2001 GBM Landau 34' Class A
Edd505
Elephant Butte, NM
Posted: 06/29/21 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Try here Hi Spec Wheel
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
jdc1
Rescue, Ca
Posted: 06/30/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
The biggest obstruction might be the front end wheel-well. Do a clock-to-clock turn, having someone make sure there is room for the taller tire.
RLS7201
Posted: 06/30/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Once you consider the cost of 19.5 tires and wheels. Think about the best 235/85R16 tire for your MH. Michelin XPS is the tire Ford picked as OEM, for a reason. The XPS has all steel cord construction and that helps eliminate tire side wall flex. I run nothing but Michelin XPS tires on my coach with never a problem. The drive and handling is good.
You current 235/85R16 tires are 32" in diameter. Try and maintain the diameter if you insist on changing wheel size.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
C20
Shawnee KS
Posted: 06/30/21 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
You might check boar wheels. Not sure they are for your application but they are awesome on trailers.
2015 Monaco Dynasty
97 jeep wrangler
16 HD CVO Street glide
2015 Challenger Hellcat
2020 ram 2500 Cummins
chuckftboy
Fleming Island, Florida
Posted: 07/01/21 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
A larger wheel will take a larger tire so expect your speedometer and odometer to be off considerably. You could use a good GPS to monitor speed
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
