RV.Net Open Roads Forum: Tech Issues: Electrical Issue
 > Electrical Issue
PepperDad51
Tennessee
Posted: 06/30/21 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
I am finding out that the Todd converter wasn't very good and the company is no longer in business
BFL13
Victoria, BC
Posted: 06/30/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Here is one option at a good price:
https://www.boatandrvaccessories.com/pro........th-led-light?_pos=1&_sid=fdda00f01&_ss=r
They make a 45 but seem to be out of stock here. Amazon? you can use a 55 in place of your 45 ok.
Instructions for using it here:
https://powermaxconverters.com/wp-content/uploads/2021/04/PM3-Owners-Manual.pdf
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 06/30/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Just throwing this out: I thought I read that you had disconnected the batteries, if so are you 100% sure you connected them back up correctly??
In the RV world Black is generally the Plus 12 Line, if you connected things backwards it might explain the burnt smell.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
enblethen
Moses Lake, WA
Posted: 06/30/21 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Some older converters had two outputs, One clean power and one dirty,
I would suggest replacing the converter and power distribution panel with a new more efficient one.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
larry cad
ohio
Posted: 07/01/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Is it possible the red wire you mentioned has become loose in the converter connection? If the red wire is loose and burnt as a result of the loose connection, simply clean the connection, and tighten the connector. This could be a simple problem and it is certainly worth a try before you spend a lot of money on a new converter.
A bad converter would not typically burn the output (red) wire.
Our Travel Blog
 > Electrical Issue
