RV.Net Open Roads Forum: Class A Motorhomes: No power to dash
Omer&Donna
Lake Havasu City, AZ
Posted: 07/01/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
After an overnight stop in our 2008 Allegro Bay we have no power to the dash AC, radio, seats, and DC plug. Speedometer and rear camera are fine. Circuit breakers and fuses are all ok that we can find (under fridge and in dash). Checked under dash for disconnected wires and found no problems. Any suggestions are appreciated.
2008 Tiffin Allegro Bay, 35'
1998 Jeep Wrangler
Ranger Smith
Wherever the rig is parked
Posted: 07/01/21 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Gotta be a blown fuse. Pull em one at a time and check them. Also a test light comes in handy with the rig running.
Where we are now
Amateur Radio Operator WW1SS . . . Yaesu FTDX101D, Ameritron AL-80 Amp, Icom 7100, Yaesu FT-991A
Steve and Joy
2010 Allegro Bus 43 QBP . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
enblethen
Moses Lake, WA
Posted: 07/01/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
My rig has an "IGN' relay that engages 10-15 seconds after engine start. It has a circuit breaker. Both are located in the battery control center.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Yosemite Sam1
Under the pines.
Posted: 07/01/21 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
Blown fuse, that happened to me in Utah.
Afterwards check the load on your cigarette lighter or USB's. Cell phone charging, iPads, back-up cameras etc. Rule of thumb should not be more than 3.
dougrainer
Carrolton, Texas
Posted: 07/02/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Tiffins have a 100 amp solenoid for the OEM Dash add ons. Odds are the solenoid has stuck OFF. What you can do for a quick test(does not always work) is to rapidly cycle the ON OFF key switch 10 times or so. IF you restore power, that solenoid is bad. It is located either in the LF storage bay, or the bay front or rear of the entry door. Doug
crawford
Dandridge Tenn.
Posted: 07/04/21 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Nope start looking for a bad ground even a rusty one will do it. There are many grounds in that unit but start with battery to frame the enging to frame so forth.
Change from a c class to a A class Georgetown 07 triple slide
dougrainer
Carrolton, Texas
Posted: 07/04/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
How come people never suggest to look for a loose/bad POSITIVE connection????????????????????????????? Doug
enblethen
Moses Lake, WA
Posted: 07/04/21 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Too many posts saying it is always the ground!
dougrainer
Carrolton, Texas
Posted: 07/04/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I know, MY pet peeve. after 42 years as a Tech it is RARELY the ground[emoticon] Doug
crawford
Dandridge Tenn.
Posted: 07/06/21 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Maybe because the flow of electric is neg to pos if you check his post you will see it has many circuits and a ground cover many. Not like a fuse line a few in line it wouldn't jump all over the system. A ground and cover many and rust and cause a lost of problems.
