RV.Net Open Roads Forum: Class C Motorhomes: Electrical issue
 > Electrical issue
Cmccain13
Posted: 07/01/21 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Ok this is the situation. I am staying at a friends house/farm they set up a 30 amp plug for me to hook up to. (I already have a power surge protector on order now) well we hooked up and my breaker box started smoking (he has "converted" a 50 amp to a 30 amp outlet). we unhooked immediately and I started up my generator, everything works fine off the generator and I'm not sure what was smoking but it seemed to be coming from the inverter(converter? I only have one of these and not sure which) my question is, if the inverter/converter was fried would everything still be working in my rig? or am I gonna be screwed when I try and hook back up to shore power at the spot I'm going to tonight.
jdc1
Rescue, Ca
Posted: 07/01/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
He has a 30 amp 220V set-up. Your 30 amp is only 110 Volt. Hopefully nothing is fried.
time2roll
Posted: 07/01/21 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Measure the battery voltage is 13.2+ to confirm all the smoke has not been released from the converter.
675w Solar pictures back up
enblethen
Moses Lake, WA
Posted: 07/01/21 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Check the 30 amp receptacle to insure it is 120 volts between the blades.
You may have lucked out if 240 volts and didn't waste your converter!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
stickdog
Somewhere, USA
Posted: 07/01/21 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Your friend isn't a licensed electrician is he?
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
ā€œA good traveler has no fixed plans, and is not intent on arriving.ā€ Lao Tzu
Cmccain13
Posted: 07/01/21 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
that he is not, i thought he had it professionally installed. i was wrong
wolfe10
Posted: 07/01/21 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, likely,the smoke has been let out of anything 120 VAC running before the breaker box melt down.
* This post was edited 07/01/21 03:03pm by wolfe10 *
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Posted: 07/01/21 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
^This.
If all your AC and DC fixtures and appliances are working AND you have charging voltage at the battery(s) you may have not killed the converter.
Not saying it may last forever, but???
PS, converter is basically a fancy battery charger. Turns 120V AC into 12V DC.
Inverter uses 12V DC to make 120V AC. Less common.
2016 Ram 2500, MotorOps.ca EFIlive tuned, 5ā€ turbo back, 6" lift on 37s
2017 Heartland Torque T29
Flute Man
Payson, Arizona
Posted: 07/01/21 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Unless otherwise defined a normal 30 amp household connection is 220 V like for a dryer. The electrician has to be told that this 30 amp outlet Is for an RV and only 120 V. Not the electricians fault.
The converter probably is definitely fried. You might as well plan Iā€™m replacing it.
And any other 120 V appliance that happened be on at the same time.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
time2roll
Posted: 07/01/21 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
So it is OK to ignore the indicated 125V embossed on the connector?
 > Electrical issue
