RV.Net Open Roads Forum: Towing Honda CR-V with Pride scooter on the back
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  All
 > Towing Honda CR-V with Pride scooter on the back
mikestock
Vestavia Hills, AL, USA
Posted: 07/01/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
We tow a CR-V with a Pride scooter on the back with a platform that adds another 200 lbs. cantalevered off the 2" receiver hitch. It has to be taking a toll on the rear suspension and I have read about other people who have had issues, after using a lift like this, on a small SUV.
Does anyone have a suggestion where I can get help to assure that I'm not causing a failure in the rear suspension by continuing bounce the scooter around the country?
Quartzsite, AZ
Posted: 07/01/21 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Does the rear axel weight exceed the manufacturer's limits?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Y-Guy
Tri-Cities, WA
Posted: 07/01/21 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
mikestock, I think the only source that I can think of will be Honda. I'd see if you can talk to a service manager. They will know what the ratings are for the suspension and can best advise you.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
Beverley&Ken
Tottenham,Ontario
Posted: 07/01/21 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
200 pounds should be OK providing that you do not have the cargo area filled with another few hundred pounds. I think that the the carrying capacity for the CVR (2012) is about 850 lbs, which includes driver and passengers (but there won't be any).
My concern would be the flexing or bounce on the hitch. Have someone follow you for a few miles and see how much flexing there is. (think a bicycle carrier on the back of a trailer). Our class 3/2" receiver hitch is bolted to the CRV "frame!? which is heavy guage sheet metal.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
mikestock
Posted: 07/02/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
My concern is not the actual total vertical load but the cantalever affect of the load being about 6 to 7 ft. from the rear axle and the constant bouncing.
I haven't found any helper springs or air bags that can be added to the CR-V. That's what I would really like.
Beverley&Ken
Tottenham,Ontario
Posted: 07/03/21 10:08am Link  |  Quote  |  Print  |  Notify Moderator
I don’t think That you will find any suspension upgrades for the rear CRV suspension is a coil overs strut sold as a single unit.
What I did was to use a set of Harbor Freight ratchet straps, in addition to the regular tie downs. One end was anchored to the outside ends of the hitch receiver and crossed over to the opposite end of the bike, handle bar or seat area. When they were snugged down, it reduced the bouncing considerably. Basically a 3 point connection to the car (or MH) receiver frame (edit add), instead of the one point receiver draw bar which tends to be a sloppy bouncy connection anyway.
Ken
mikestock
Posted: 07/06/21 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Ken
Great point made.
I haven't thought of doing something like this to address the bouncing. The bouncing can do much more damage that the static load. I can tie the upper frame of the carrier to my overhead roof rack and hope I don't rip the roof rack loose.
I once had an very light aluminum bike attached to the ladder on a fifth wheel that almost took the ladder down in a cross-country trip.
Healeyman
Carrollton, TX
Posted: 07/06/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
mikestock wrote:
Does anyone have a suggestion...
Mike,
As an alternative to beefing up your CRV suspension, you might look at lightening the load.
As I have aged, my distance walking ability has become shorter and shorter.
I recently bought a GLION Snap-N-Go mobility scooter, Model 325.
Without the seat and battery it weighs 30 pounds, about 40# with the seat and battery. GLION has an accessory (large) bicycle style TRAVEL seat without the back or arm rests. I use that most of the time. That seat mounts to the frame during transport.
It is not only LIGHT, but the steering tiller folds down so that it can easily be carried in the back of your SUV. We carry it in the back of our Chev Equinox. I have even carried it on the trunk-mounted luggage rack of my Miata.
When folded, using the footrests, it can be easily trailered like a suitcase.
HERE is a link to the Snap-N-Go Operations video. Skip the ad to see the video.
I'm sure that you can find a dealer for them or the GLION web site or Amazon has them.
PM me if I can help you with any additional information.
Tim
* This post was edited 07/06/21 02:01pm by Healeyman *
Ivylog
Blairsville, GA and WPB, FL.
Posted: 07/06/21 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
I would be worried the hitch will eventually separate from the sheet metal. I would put it on the back of your Phaeton.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
mikestock
Posted: 07/07/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
The back of the Phaeton is where the CR-V goes. Can't travel without the CR-V. Rental cars are nearly impossible. The Pride has to ride on the back of the CR-V.
