RV.Net Open Roads Forum: Class A Motorhomes: Inside tire valve extensions
 > Inside tire valve extensions
MetalGator
Posted: 07/01/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Went to get the motorhome out of our storage garage today. My TPS system usually takes a minute or two to kick in once driving. The low pressure alarm went off. My motorhome says to keep tire pressure at 90psi but I normally keep them a few PSI above 90. My right rear inside tire was indicating 62 PSI and the other 5 tires were between 93-96 psi. I only live about 4 miles from my house so I drove slow and parked in the driveway. I have a big air compressor in my storage garage but I have a small one at the house. I was able to get the PSI in the low tire up to 76 PSI with my little compressor and drove slowly to a local tire place that does truck tires.
As soon as the tire guy came out, he said your problem is probably that tire valve extension. He said 90 % of the time, a slow leak on an inner tire is because of the valve extension. I don't know if he tightened the extension or put a new one on but he said its fixed now (so far PSI is the same).
Is this a common problem? If so, what is the fix? If there wasn't an extension I am scratching my head wondering how you air up the inner tire?
I guess I will know if the issue is fixed tomorrow but so far PSI hasn't changed on that tire since it cooled down from the drive home.
Burch
2018 Miramar 35.3
2005 Dodge Ram Quad Cab 1500
3 fur kids (Monty, Lola and Pinto)
Rainbow bridge (Murphy)
Posted: 07/01/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Two very common issues
Tire valve extensions especially the flexible kind (more on that in a bit)
And screw on TPMS sensors.
I went with Dully Valves on my Rig when I put on new shoes (Tires) they are metal and are really very long or very bent valve stems. Loved those things.
two travelers
Smithtown, NY
Posted: 07/01/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I also had problems with the flexible extender. It only leaked when driven was found quite by accident by my mechanic. When I got new tires, I went with solid extenders on all wheels.
routeforty
ohio
Posted: 07/01/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
I put metal valve extensions(from NAPA) on my MH. When I screwed them on it began to leak. I backed off a couple turns until the leak stopped. Haven't had a problem in 20k miles.
2018 coachmen leprechaun class c
larry cad
ohio
Posted: 07/02/21 04:34am Link  |  Quote  |  Print  |  Notify Moderator
I think John meant to say "DUALLY VALVES"
Dually Valves
Our Travel Blog
scbwr
North Ridgeville, OH
Posted: 07/02/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
Dually Valves
I ordered the dually kit from yourtireshopsupply.com (link above) and it was one of the best things I've done for my rig. I was having trouble with extensions....the one piece valve stems are the way to go and work well with TPMS sensors.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
oldave
Tx
Posted: 07/02/21 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I have learned the hard way that extensions are just another possible
problem.
The best solution is a new stem specially shaped to bring the end out
where you want it.
They are available at the link above, here it is again.
Dually Valves
Dale.Traveling
Newport News, VA
Posted: 07/02/21 08:10am Link  |  Quote  |  Print  |  Notify Moderator
MetalGator wrote:
,,,Is this a common problem?,,,
It can be a problem but having extensions should not be a reason not to inspect the tire for damage such as nails or a sidewall abrasion along with checking the valve stem seal and the extension. A little soapy water goes a long way with the confidence that the trip will be uneventful.
I've had two leaks. The valve stem seal that went while going down the road before I had a TPMS (destroyed the tire before I could get off the road) and a slow leak at the bead seal, post TPMS, after new tires were installed. Not had any problems with the extensions.
2006 Hurricane 31D built on a 2006 Ford F53
atsrmf
Indio
Posted: 07/08/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Buy a pair of these, I'm glad that I did! Be sure to order the correct pressure.
Crossfire
scbwr
Posted: 07/08/21 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for
https://yourtireshopsupply.com/category/796/dually-valve-kits
