RV.Net Open Roads Forum: Tech Issues: Armoured extension cord
 > Armoured extension cord
Page of 5
swimmer_spe
Sudbury, Ontario, Canada
Posted: 07/01/21 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I need an armoured extension cord to power my RV at home, but I need it to cross the driveway, so it will be run over by the vehicles. Any suggestions?
Boon Docker
Posted: 07/01/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Remove one end (plug) from cord and put cord inside a 3/4 inch PVC pipe, then reinstall a new plug.
RedRollingRoadblock
Oregon
Posted: 07/01/21 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Three pieces of 1X4 or some 3/4 inch plywood by how ever long your need. Lay two pieces on either side of the cord and bridge the gap and cord with the third. Secure with small screws, washers and nuts.
Gdetrailer
PA
Posted: 07/01/21 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
No such thing exists and if it did would be more expensive than your RV.
The closest thing to armored cable that I can think of is this
"BX" cable, but, it is not designed for and cannot be used for outdoor use, it is not designed to be run over..
Find a different route such as overhead or take it the long way around or bury conduit under the driveway and run some wire through the conduit and terminate to a RV outlet.
You could also try cord protectors that look like this..
That one is rated for 22,000 lbs but it is expensive for a 40" length..
Found HERE for $52.00
gbopp
The Keystone State
Posted: 07/01/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
X2. Do it right and do it one time.
time2roll
Posted: 07/01/21 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Pull the wire under the driveway. Or have a professional do it. You may already have a slip pipe to route irrigation.
675w Solar pictures back up
swimmer_spe
Posted: 07/01/21 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Those covers might be a better way to go.
Posted: 07/01/21 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Ease off the coffee and metamucil, guys....
Bore under the driveway? Put up an overhead line? I mean I suppose if it's going to be there for years, but then an extension cord in and of itself wouldnt be the right choice.
spe
Build a cord protector out of wood, buy one like above, stuff the cord in small piece of pipe, or anything similar. Easy peasy. We do this daily to drive semis and construction equipment over cords and hoses on jobsites. Pretty sure it will work for your car.
PS it's even OSHA approved for the "do it right" cops who replied...
2017 Heartland Torque T29
Beverley&Ken
Tottenham,Ontario
Posted: 07/01/21 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
What material is your driveway made from, hard surface, asphalt (blacktop) concrete , the above suggestions are great, gravel stone etc, uneven, then questionable especially if there are tire depressions.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
swimmer_spe
Posted: 07/01/21 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
Packed gravel and there are tire depressions.
Page of 5
