RV.Net Open Roads Forum: Class A Motorhomes: Newmar DutchStar Chrome Exhaust Tip
 > Newmar DutchStar Chrome Exhaust Tip
kmb1966
Lake Charles
Posted: 07/03/21 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2003 Newmar Dutchstar Freightliner chassis where the chrome exhaust tip has came off. It's a 5" tip and it is somewhat worn, but what made it fall off is the sleeve that u-bolts to the tip and slides into the muffler with another u-bolt clamp has rusted through. I would like to replace the coupling sleeve and the chrome tip, but I am unsure where to go to find a replacement. Can anyone point me in the right direction please?
bgum
South Louisiana
Posted: 07/03/21 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
What is the diameter and Length?
bgum
South Louisiana
Posted: 07/03/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon about $75
kmb1966
Lake Charles
Posted: 07/03/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
The chrome tip that points downward is: 20"
The inner diameter seems to be 5"
the sleeve goes inside the tip and inside the muffler and there is a u-bolt on each on the outside clamping it together
Corkey05
Washington State
Posted: 07/03/21 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
You could change the filtering criteria for different results, but here's a good place to start.
5" Chrome/Stainless Exhaust Tip
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
kmb1966
Lake Charles
Posted: 07/03/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
where can I get the inner sleeve that connects the chrome tip to the muffler?
Corkey05
Washington State
Posted: 07/03/21 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
I've never seen the sleeve separate without the tip. They are usually sold together as a set. Maybe a truck service center or muffler shop might have a source.
Ray,IN
IN, USA
Posted: 07/03/21 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
The 5" chrome tip may be found on Amazon, but the best place is Iowa 80 truck stopIowa 80 truck stop to find it and the sleeve.
And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
larry cad
ohio
Posted: 07/04/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
As mentioned many times, the chrome tip is available from several sources, although a stainless tip will hold up better than chrome.
Your second question is where to get the sleeve from the muffler to the chrome tip, and the u-bolts. The sleeve should actually go OVER the muffler output, not into it. This helps to minimize leaks. Then the tip will go OVER the sleeve. Some auto parts stores have short pieces of sleeve with the larger inlet end. A better choice would be a diesel truck service shop. U-bolts are a common item. Again, auto parts stores, or truck service shops.
Our Travel Blog
Mel Stuplich
Wausau, WI
Posted: 07/04/21 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.ebay.com/itm/133345678386?_t........s4AZSqHVzUH_fSxkgmvtybm7h4RoCEsIQAvD_BwE
* This post was edited 07/06/21 12:50pm by an administrator/moderator *
