RV.Net Open Roads Forum: Tow Vehicles: 2018 Expedition - Rear spring upgrade
Search only in Tow Vehicles
 > 2018 Expedition - Rear spring upgrade
BenK
SF BayArea
Posted: 07/13/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Independent rear suspension (IRS) and adding helper springs introduces different moments & loading vs a live axle.
Also, the lower link is at an angle. As would be the pivot point at the pumpkin attachment area to handle the cantilever moment, the tire/pavement has both forward and reverse.
The stoutness between a live axle and IRS has the Live axle's ability higher.
With that, adding a higher rate coil spring, a better approach vs any of the aux springs that place their contact point on that lower link.
Suggest looking into the highest WD Bars to get more weight off of the TV's rear and WD'd to the TV's front...of course within the TT's tongue 'actual' weight.
-Ben Picture of my rig
