RV.Net Open Roads Forum: Looking for end all be all air pump
 > Looking for end all be all air pump
mr_andyj
Georgia
Posted: 07/10/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
I use a hair drier for an air mattress. It has a COLD setting, which you need. There are DC powered hair driers. Unlike the electric pumps, hair driers can run 100% duty cycles and will move a lot of air, but just not at high pressures. For a boat you do not need more that the hair drier can do, but if you do then just top it off with a different pump.
A short internet non-google search for pumps that actual boaters use will turn up a lot of really good options.
Again, there is no one pump for everything outside of a full-blown air compressor.
Did you plan to inflate a big Grand Canyon sized raft or just small things? Those big pumps mentioned will be ideal for non-electric needs. (it is a hand pump you hold with your foot, it has a stirrup, and the can is about the size of a 2 liter bottle. It moves a lot of air.
EMD360
Arvada, CO
Posted: 07/10/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Mr_andyj: How do you attach a hair dryer to the air input?
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
frankwp
Calgary, AB, Canada
Posted: 07/11/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
I've been using a Milwaukee M18 toolbox vac (0880-20) for the past few years to inflate our air mattresses & water inflatables. It inflates them fast & firm & just as importantly, will suck them thoroughly flat for storage. The vacuum is quite inexpensive, especially if you're already in the M18 ecosystem.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
