RV.Net Open Roads Forum: Class B - Camping Van Conversions: Battery/Inverter
Open Roads Forum  >  Class B - Camping Van Conversions  >  DIY
 > Battery/Inverter
JimWulff
Colorado
Posted: 07/05/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
I'm getting ready to change from wet cell batteries to AGM in my 2008 Roadtrek 210 Versatile. My two questions are:
(1) do I need to change the inverter dip switch position from wet cell to gel?
(2) how does one access the inverter in this model of Roadtrek? Where do they put it? All I can see is the inverter switch and nothing more.
Thanks!
agwill
enosburg falls, vt
Posted: 07/05/21 11:39am Link  |  Quote  |  Print  |  Notify Moderator
AGM is a wet cell.
al
time2roll
Posted: 07/05/21 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the switches should be changed to AGM to avoid any equalization.
675w Solar pictures back up
KD4UPL
Swoope, VA
Posted: 07/05/21 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
If your only choices are wet cell and gel then for AGM you want wet cell. If you actually have a setting for AGM then use that.
But, the best thing to do is to look up the exact charging voltages recommended for your particular brand of battery. Then, look up the actual charging voltages that each switch setting will give you and make the closest match you can.
 > Battery/Inverter
