RV.Net Open Roads Forum: Technology Corner: Connecting Winegard Traveler to Dish Hopper
 > Connecting Winegard Traveler to Dish Hopper
fotodog
San Francisco, CA
Posted: 07/05/21 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Hello All,
My apologies if this has been addressed, but I can’t find any information with a search. My old Dish receiver bit the dust, and I’m now trying to connect the new Hopper to my Winegard rooftop satellite dish. The problem I’m having is that my 2008 Tiffen uses a control box which connects both TV’s to either the rooftop analog antenna, campground cable, or satellite dish by pressing the appropriate switch, but it only has coaxial connections.
With my old Dish receiver, I plugged the incoming satellite cable into a splitter, with one leg going to the receiver and the other leg going to the control box. But the new Hopper only has one coaxial input, so I don’t have a way to connect it to the control box.
Do I need a new control box? If anyone has experience with this, I would greatly appreciate your help. Thanks! Tim
Tim, my wife Li, and Snickers and Ziggy the Wonder Kitties
2008 Tiffen Allegro 30DA, Workhorse W22 Chassis, Allison 6 speed, Chevy 8.1L V8
2015 Jeep Cherokee with Blue Ox baseplate & ReadyBrake system
http://www.timandrews.com/ My photography web site
LouLawrence
Traveling the US!
Posted: 07/06/21 07:28am Link  |  Quote  |  Print  |  Notify Moderator
If you are talking about getting the TV signal from the Hopper to more than 1 TV there is no coax option available as the output is HDMI. You could add an wireless HDMI splitter/repeater and connect that to the 2nd TV but they are not cheap. If you have the ability to run a new HDMI cable from the Hopper to the 2nd TV then you only need the splitter to get the signal there. You may find some HDMI to coax (usually poor quality picture) or CAT6 Ethernet if you don't have room to run a new HDMI cable. Keep in mind you could run the coax up through the ceiling to the roof, across the roof and back into the RV at the new location, it just takes a longer cable.
If you do have the Winegard Trav'ler SK-1000 for DISH, you can also just run a 2nd coax to the 2nd TV from the antenna and use a Joey at that location.
CarnationSailor
Carnation,WA
Posted: 07/06/21 11:47am Link  |  Quote  |  Print  |  Notify Moderator
You could also use a wireless Joey at the 2nd TV location.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
fotodog
San Francisco, CA
Posted: 07/06/21 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies gentlemen, but I may not have been clear in my first post. I need a way to connect the Hopper to the video control box. Right now I cannot watch satellite TV on the main TV, much less the 2nd one.
The Hopper only has one coaxial connection for the incoming signal, where the old Dish receiver had that plus a “home distribution port” coaxial connection that would connect the receiver to the control box. If the only solution is running new cables in the RV, I might be better off buying an older receiver off Ebay.
Thunder Mountain
Lost in the Four Corners
Posted: 07/06/21 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
Do a search on using a Dish Hopper3 in an RV. Start by reading this: https://rvseniormoments.com/tech-docs/dish-tv-for-rvs/hopper-3-use-in-an-rv/dph42-switch-hopper-3-option-instead-of-modifying-your-travler/
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
Retired JSO
North Georgia Mountains
Posted: 07/06/21 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Use an RF Modulator which uses the video output in your receiver to send the signal to a cable.
Dutch_12078
Winters south, summers north
Posted: 07/06/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Here's another modulator option:
HDMI RF Modulator Coax Adapter 1080P Inp........l Output Converter with Male F Type Cord
Dutch
2001 GBM Landau 34' Class A
LouLawrence
Traveling the US!
Posted: 07/06/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
The RF modulator will take your HD output from the Hopper and convert it to SD even if the TV is HD capable. I was assuming you would like to have HD TV on your TV's. You were clear but a simple answer is not available.
TechWriter
On The Road
Posted: 07/06/21 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of assumptions on my part . . .
You're using a Hopper 3. Your Tiffin control box in connected to the ANTENNA IN of your TVs.
If that's that case, you could probably still use your Tiffin control box for OTA TV and park cable, but I don't recommend using it for HD TV.
Here's what I did . . .
A couple of notes . . .
- I used a Channel Plus Video Amp. You could probably still use your Tiffin box.
- I used hard wired Joey 2s. You could also use wireless Joeys, or wireless HDMI. However, I do NOT recommend a RF modulator unless you want crummy looking TV.
- If your Winegard Traveler is newer (2018+), you can install a DPH LNBF on it. Then you can run a single wire from the Winegard instead of three. Plus, you won't need the DPH42 switch.
* This post was edited 07/06/21 07:58pm by TechWriter *
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 gasser)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 gasser)
www.rvSeniorMoments.com
DISH TV for RVs
fotodog
San Francisco, CA
Posted: 07/06/21 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Gentlemen, thanks again for all your replies. Everyone has been so generous with your time and sharing your knowledge. I have spent the last few hours doing more research and, as with many things, it’s more complicated than first thought. Compatibility is a big problem as technology advances so quickly. I found that out in my business once photography went digital. Top of the line camera systems became practically obsolete in 5 years.
My 2008 Allegro was one of the last years with analog SD TV’s. Since our RV trips are limited and we spend much of our time outdoors, TV was never a priority and we never upgraded to HD. So for now, a RF modulator would probably be fine if that, combined with the DPH42 , would allow me to use my current setup to view both front and rear TV’s.
Tom, you obviously have a LOT of experience doing this. Much of my research was reading your writing on the subject. I’m not clear on how to connect the DPH42 to the dish. The RV Tech who installed my Winegard system has always done great work with attention to detail. He ran one of the lines from the dish to the Winegard box, the second line plugs into the Dish receiver, and the third line is unused. Your wiring diagrams never indicate how the Winegard box is wired, or maybe they do and I’m just not seeing it. Can you please clarify? Thanks!
Tim
