RV.Net Open Roads Forum: Dinghy Towing: Recomended Tow Bar Clevis?
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Tow Bars
 > Recomended Tow Bar Clevis?
obgraham
TriCites WA
Posted: 07/06/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Slight deviation here: On my setup, the Roadmaster pins were of slightly different design, but same purpose.
But there were connections also between the bar and the MoHo, and between the brackets and the Toad. All with locking pins.
However, I secured the other pins with padlocks, not the wire jigglies. You just never know when some miscreant will mess with them, or loosen the wirelocks. Each setup is a bit different, but the plan remains.
On the other hand, you don't want to padlock those big main pins, in case you have to release the toad in a hurry.
Posted: 07/20/21 01:02am Link  |  Quote  |  Print  |  Notify Moderator
Y-Guy wrote:
GD so the Ready Brute Tow Bar and the Jeep bumper adapter from Rock Hard 4x4 have options to fit Blue Ox, RoadMaster, or Reese clevis. Maybe I'm totally over thinking it (probably am) but at first glace the Blue Ox/Demco style clevis seemed to be possible a better setup.
Big fan of Ranch & Home too, drive by it at least twice a day.
Look like hitch pins to me. Any hitch pin or hardened bolts will be sufficient.
2017 Heartland Torque T29
