RV.Net Open Roads Forum: Class A Motorhomes: 80's 454 fuel supply challenges
 > 80's 454 fuel supply challenges
Jarlaxle
New England
Posted: 07/21/21 12:16am Link  |  Quote  |  Print  |  Notify Moderator
Probably not, with EFI.
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. ">
Current rig:
1992 International Genesis school bus conversion
2 many 2
Posted: 08/02/21 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Any Up-Dates?
udidwht
Seattle
Posted: 08/03/21 01:44am Link  |  Quote  |  Print  |  Notify Moderator
For TBI troubleshooting...
https://harristuning.com/Tbi/troubleshooting/
94-95 TBI years were 26-32psi fuel pressure. You also need to be sure you're running the correct flow rated injectors for your year engine. Only use AC Delco parts. Do not cheap out.
Even a bad TPS can cause the issue you're having.
You mention 220 - 280 temps?
The dash gauge even have 280? Or is it 260?
Those year coaches run with a 195 T-stat. Do not use one less than that. It will throw off the PCM. I'd also pull the distributor and replace the pick-up coil and stator ring. The ring is known to crack messing with timing.
* This post was edited 08/03/21 01:55am by udidwht *
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 58,301 miles and counting....(as of 06/08/19)
VIN# 1GBJP37N4R3314754
