RV.Net Open Roads Forum: Help getting fridge to run while underway
 > Help getting fridge to run while underway
fijidad
Escondido, CA
Posted: 07/06/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Our fridge and freezer run under these conditions: 1) while plugged into shore power, 2) on the inverter...with engine off, and 3) on propane...with engine off.
When I start the engine, however, the fridge and freezer do not function. I get an alarm sounding and codes flashing. The code indicated the problem is not something I can resolve, but need to take it to a dealer.
Just checking with the community before I go through that hassle...again.
Among my frustrations is that I've already taken it to San Diego RV and they told me just to reverse the plugs to the refer and ice maker. They didn't test it or fix it. When I later did that, I got the same results.
Any thoughts?
MountainAir05
New Mexico
Posted: 07/06/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you are loosing 12v when the engine is running. Easy to check on the back of the refrigrator. I will take a shot that the house battery does not get charge when the engine is running. Next time post what brand refrigator and year would be helpful. I would say to check the Alternator isolator to start with battery voltage.
clicky
* This post was edited 07/06/21 04:43pm by MountainAir05 *
enblethen
Moses Lake, WA
Posted: 07/06/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
House battery disconnect may not be energized.
Cycle battery disconnect on and off several times. You should hear a sound click.
Make and model of rig?
Make and model of refer? Residential?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Flute Man
Payson, Arizona
Posted: 07/06/21 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
My fridge automatically switches to Propane when I am not on shore power. It also runs on propane when my big engine is running. Don’t exactly know what yours is supposed to do but I suspect that the operation should be similar. Most RVs that I know of operate that way like mine. If you call me I will help you over the phone to troubleshoot.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
time2roll
Posted: 07/06/21 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Does it run in motion on the inverter? I believe that is the solution.
675w Solar pictures back up
accsys
Green Cove Springs, FL
Posted: 07/07/21 06:22am Link  |  Quote  |  Print  |  Notify Moderator
It would help TREMENDOUSLY if we knew the make, model and year of your motorhome!!! They are all different and each has its own idiosyncrasies.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
dougrainer
Carrolton, Texas
Posted: 07/07/21 09:15am Link  |  Quote  |  Print  |  Notify Moderator
AND the Model and Brand of refer. He appears to have a Monaco and that would be a 1200 Norcold OR a 2110 Norcold. Now one of his older posts indicates what the dealer told him about the 2 rear AC outlet plugs behind the refer. There are 2 plugs on the Back of the refer.
One plug is connected thru the Inverter and is dedicated to the Icemaker so you can make Ice when traveling and on Inverter. The 2nd plug is the standard 120 plug bypassing the Inverter to run the Refer on LP or 120. 120 when on Genset or Shore Power. It appears he swapped the cords per his dumb dealers recommendation. SO, that means when the Inverter is ON, his refer runs on 120 regardless when refer set to AUTO. The ONLY way to get it to run on LP is to go to the refer and set the refer to LP ONLY. Now, he states he has a problem when starting the engine and the refer goes haywire. That would appear to mean that he may have messed with the coach batteries or battery system. He also needs to state WHAT error codes are showing on the refer. There is NO interconnect on a Monaco between the Ignition ON or OFF, so that points to something wrong with the battery system. WE need a lot more info to help him out. Doug
Posted: 07/07/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
What is the code?
One possibility is the fridge is losing 12 volts when you crank it up
Recommend running on propane by the way If you drive very far the fridge sucks power faster than the tow vehicle will provide it.
Another option is over voltage.. The Tow vehicle may be pushing too much power. There are ways to load the charge line a bit to reduce that.
But we need the code.
larry cad
ohio
Posted: 07/08/21 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Well said. I only hope the OP reads this!
Our Travel Blog
fijidad
Escondido, CA
Posted: 07/08/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Took me a while to get back to the storage yard where we have our RV parked. I've taken pictures of the fridge and some others I hope are helpful...unhappily, I can't figure out how to post them from my files. My thought is this is not a fridge problem, but rather something external to it...the power supply is disrupted to it when I start the drive engine. The code the fridge puts out when I start the drive engine is "no a/c." Why the propane supply would also be disrupted is a mystery. I can do some repairs myself if they're pretty straightforward, so would like to not have to take it back to a repair facility if possible. Thanks, Dan
