RV.Net Open Roads Forum: Help getting fridge to run while underway
 > Help getting fridge to run while underway
dougrainer
Carrolton, Texas
Posted: 07/08/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
fijidad wrote:
Took me a while to get back to the storage yard where we have our RV parked. I've taken pictures of the fridge and some others I hope are helpful...unhappily, I can't figure out how to post them from my files. My thought is this is not a fridge problem, but rather something external to it...the power supply is disrupted to it when I start the drive engine. The code the fridge puts out when I start the drive engine is "no a/c." Why the propane supply would also be disrupted is a mystery. I can do some repairs myself if they're pretty straightforward, so would like to not have to take it back to a repair facility if possible. Thanks, Dan
You have a Norcold 1200. You have 3 modes to set the refer
AUTO
AC
LP
If on Auto, and it states NO ac, it should go to LP
If on AC, it will state NO AC if NO AC but will NOT go to LP
If on LP then it will NOT state NO ac and will operate on LP
accsys
Green Cove Springs, FL
Posted: 07/08/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Still don't know what kind of rig it is so will not waste time guessing. It sounds like a 12V problem that occurred when the system switched from the converter to the alternator and perhaps popped a circuit breaker but really need more info.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
dougrainer
Carrolton, Texas
Posted: 07/08/21 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
2002 Monaco Windsor. Doug
time2roll
Posted: 07/08/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Any chance it has a propane detector that actually shuts off the propane?
675w Solar pictures back up
dougrainer
Carrolton, Texas
Posted: 07/09/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Not on Monaco. Doug
If so, it would show NO FL
enblethen
Moses Lake, WA
Posted: 07/09/21 07:37am Link  |  Quote  |  Print  |  Notify Moderator
It takes 12 volts DC to operate the refer.
Best place to operate the refer, is on auto.
I would suggest putting meter on 12 volt supply to refer and see what happens when helper starts the rig.
I would test coach batteries. Check 12 volts DC to refer in all operational conditions. Operate refer manually in propane and 120 volts AC.
Check salesman switch.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
fijidad
Escondido, CA
Posted: 09/09/21 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Well, I think I'm in the final leg of this issue...I've spoken to Senior Member Jerry Parr, and Richard, a retired mobile RV mechanic, in pursuing why our fridge wouldn't operate correctly. Jerry suggested I call Norcold and run this by them. I did and they said if the red light on the Recall Kit black box was on solid, then that box was probably bad. They said go to Camping World and order a new one for free. I did and now I'm waiting for it to arrive. In the meantime, Richard suggested connecting the two 12 volt wires from that box together...basically they way it came from the factory...I did and now the fridge works fine in every situation. I asked the Norcold rep. how long the Recall Kit boxes are good for...she said some last 10 years, and some much less. I think mine had a couple of different phases of failure, as the symptoms changed a bit over time, but I'm a happy camper now that I tracked it down to the Recall Kit.
dodge guy
Bartlett IL
Posted: 09/09/21 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
Install the new box. All should be good.
If you have to bypass it again maybe look into a residential fridge.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
dougrainer
Carrolton, Texas
Posted: 09/09/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
IF the recall box is installed correctly, it will show LiOP when the red led light on the box comes ON. You NEVER stated that the RED LED on the recall was ON. Also, the most common cause of a failure of the recall box is if water gets into it when washing the RV and blowing water thru the refer out door. IF the recall light was ON and you got NO AC on the inside, the recall wiring is NOT installed correctly. Doug
