RV.Net Open Roads Forum: Looking for ideas on how to Roll up/store 50 amp cord
 > Looking for ideas on how to Roll up/store 50 amp cord
Page of 5
Cummins12V98
on the road
Posted: 07/09/21 10:06am Link  |  Quote  |  Print  |  Notify Moderator
For a cord to properly coil on a powered reel it needs to be a SO cord as shown here.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
poppa
Dallas, TX
Posted: 07/11/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
also if ya use a reel it should be fully unreeled be for use due to counter emf in the circuit. actually for any cord.
dodge guy
Bartlett IL
Posted: 07/12/21 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Mine is just looped and stored in the electric bay. Mine is also hardwired.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
frankwp
Calgary, AB, Canada
Posted: 07/12/21 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, but you've got some mixed up info there. Counter-EMF does not come into play at all in this situation. Maybe you're thinking of electric motor windings.
The reason for not using the cord while it's not fully unreeled is that if it's being used at anywhere near its capacity, the portion that's still on the reel can overheat to the point of melting or even starting a fire.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
JRscooby
Indepmo
Posted: 07/13/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Never worked with heavy power cord, but with heavy extension cables for a winch I found that coiling around a drum by hand is nearly impossible. But feed it into a cylinder, much easier. (Haul 150 feet of 1/2 inch cable in a 14 inch car tire. Roll down to vehicle that needs pulled. Hook to load, roll back to feed out cable. At end, hook to winch cable with cable thru tire. As pull in, tire comes up with, and if breaks the tire slows the whip)
Veebyes
Posted: 07/17/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
If there is a complex expensive way to deal with something simple someone is sure to suggest it.
Cooling the 50amp beast got old real fast so a nautical method of storing awkward line is used.
It is flaked into an oval laundry basket. Enough of the female end is left out to reach the inlet. Only as much as needed is pulled out to the utility post.
Cheap and effective.
2007 Alpenlite 34RLR
blofgren
Surrey, B.C.
Posted: 07/18/21 11:03am Link  |  Quote  |  Print  |  Notify Moderator
I hear you, but you would be amazed how much better the SOOW cord is! [emoticon]
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
rhagfo
Portland, OR
Posted: 07/18/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Well if those asking would realize that the pictures I posted before are 40’ measured of 6/4 SOOW cable in a 3 gallon bucket with my 30 amp to 50 amp dog bone also.
It goes in the bucket at 28 degrees as easily as it does at 80 degrees!
* This post was edited 07/18/21 11:33am by rhagfo *
Cummins12V98
on the road
Posted: 07/18/21 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Simply look at my pic above. It's like a wet noodle.
SUMRX4
VA
Posted: 10/05/21 05:42am Link  |  Quote  |  Print  |  Notify Moderator
So where does someone buy an extension cord made with SOOW cable? I have yet to find one. I can find the cable itself sold by the foot but I have to buy the male & female plugs. Is that what your folks did or are the available complete somewhere?
Page of 5
