RV.Net Open Roads Forum: Truck Campers: Arctic fox 990 rocking back and forth
 > Arctic fox 990 rocking back and forth
Page of 7
Wingit1971
sicklerville nj
Posted: 07/07/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone,
I'm new to the truck camping world and have a few questions
I have an 2017 arctic fox slide in on a 2015 f350 SRW with airbags and rancho 9000xl shocks. I upgraded the the rims from 18's to 20's and put on bf goodrich ko2 265/70r20.When I bought this whole package it didn't rock back and forth at all, now it will rock side to side 2-3 times when until it smooths out . I have it loaded fine and the tiedowns are snug. Trying to figure out what's wrong. You would think the upgrades would've helped it. going around curves isn't a treat either. I have 55psi in the airbags and it leveled just fine and have a very slight bulge in the tire but nothing to write home about. I want to use this as a beach buggy in NJ but there's no way I can do that with this sway/ rocking. Any feedback would be helpful. This is dry weight... 4k Hate to see adding an extra 1k loaded would do.
Thanks.
notsobigjoe
southeast
Posted: 07/07/21 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your airbags are overfull.
jimh425
Western MT
Posted: 07/07/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Based on what I found online, your rear tires are way over capacity. They are only rated at 3000 lbs each. Your rear tires are probably overloaded by 1500 lbs. I agree that your air bag pressure is really high. Buy some extended bump stops and make sure the overloads are engaged.
But, the main issue is probably the tires.
Wingit1971
sicklerville nj
Posted: 07/07/21 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry i gave the wrong tire size LT 275/65 R20 126/123S e load. I also took the airbags down to 30psi to no avail
#1Flyboy
California
A good reason to move up to a Dually….
jimh425
Western MT
Posted: 07/07/21 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
What tire pressures are you running, and what are your shock settings for front/rear?
burningman
Seattle, WA USA
Posted: 07/07/21 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Rancho 9000 shocks tend to wear out extremely quickly.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Wingit1971
sicklerville nj
Posted: 07/07/21 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
80psi on the tires and setting 9 on the rancho shocks
Wingit1971
sicklerville nj
Posted: 07/07/21 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Id love a dually, but a little outta my price range. The previous owner drove this across country with no issue.
Posted: 07/07/21 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Read the thread below yours, literally the same question about virtually the same size/weight camper on a very similar truck.
Your post says you upgraded the tires and wheels and now it's rocking. My brain says you also upgraded the shocks and added the airbags also and prior to, you were riding hard on all spring and no bags and as soon as you lifted the truck off the springs at all with the bags, the body roll got more pronounced.
Your answers are in the "too much camper" thread.
2017 Heartland Torque T29
Page of 7
