RV.Net Open Roads Forum: Truck Campers: Pickup bed delete or cab chassis (C&C)?
 > Pickup bed delete or cab chassis (C&C)?
Kayteg1
California > Nevada
Posted: 07/08/21 08:32am Link  |  Quote  |  Print  |  Notify Moderator
I had several Fords in the past and C&C come with much heavier suspension.
When that might be handy for TC use, my wife refused to ride it empty due to too much shaking.
Flatbed adds few inches to the bed height. Might be important.
mr_andyj
Georgia
Posted: 07/08/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I think many of us have dreamed of putting on a flatbed. So much wasted space due to bed rails. If you use camper all the time then yes. A flatbed camper would be ideal if you find the one you like, but sure, if you need the extra square footage for tanks and tools then a slide-in fits the bill...
I never could justify the extra expense of a flatbed, and didnt really have a good place to store the truck bed for down the road when I sell truck
Kayteg1
California > Nevada
Posted: 07/08/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
For me the difference between flatbed with storage boxes and normal bed is where rednecking begins.
My basement model Fleetwood had more storage in it that we need, not to mention that you could not fill it due to weight restrictions on dually.
* This post was edited 07/08/21 09:08am by Kayteg1 *
n0arp
FT
Posted: 07/08/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Do you want more ground clearance, or lower overall height?
I think the C&C may have a lower overall height. You might try to find a lot with both and measure to the highest point on the PU frame, vs to the rails on the C&C. I think the C&C is lower but am not positive, plus it probably varies by brand. Also would need to check to see if licensing, insurance, financing (if used), etc is different between the two in your state. Pickup might be easier to deal with.
On the flipside, we gained more deck height than I planned for with the flatbed on our box delete, but the toolboxes under the bed are farther off the ground. With 20.5" of clearance below the boxes even with the camper and boxes fully loaded - I rarely have to worry about ground obstructions. And our height is right at 13', still lower than our 5er.
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
cptqueeg
Idaho
Posted: 07/08/21 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Wheels and tires are another difference.
The deck height of a flat bed is of concern w entry and exit to the TC.
n0arp
FT
Posted: 07/08/21 09:17am Link  |  Quote  |  Print  |  Notify Moderator
That's just an excuse to build a deck. Photo taken while moochdocking in a relative's driveway.
I will also add, if you're looking at a 3500, with a flatbed, it's very easy to end up overweight. Those factory wheels and tires may could benefit from upgrades (19.5s). If you aren't committed to anything yet, I'd consider springing for a 5500 where C&C is the only option.
cptqueeg
Idaho
Posted: 07/08/21 10:14am Link  |  Quote  |  Print  |  Notify Moderator
^^^ Deck looks good but the steps look scary. Imagine coming down the steps in the dark with a little wet snow on them!!!
Why a 5500/550 vs a 4500/450?
n0arp
FT
Posted: 07/08/21 10:16am Link  |  Quote  |  Print  |  Notify Moderator
We used them all winter, several times in ice and snow. Those conditions haven't been a problem. What's the issue? Lack of a hand rail? They make one that attaches if you need one. And you could easily fabricate an upper mount that drops into a socket with some parts from the hardware store. We've never felt unsafe on them, so never even thought about it.
Same chassis, but better suspension on the 5500 so you'll never have to worry at all about it.
zb39
slippery rock
Posted: 07/08/21 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Higher GVW
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
2022 Host Cascade
2021 Ram 5500 Air ride
Posted: 07/08/21 11:15am Link  |  Quote  |  Print  |  Notify Moderator
That’s just a TC thing. Tests your agility….
I used it as a cutoff point…If I fell down the steps and spilt my cocktail, it was time to switch to water!
2017 Heartland Torque T29
