RV.Net Open Roads Forum: Truck Campers: Finally made it to the Cat scales
 > Finally made it to the Cat scales
Page of 11
Longshore
California
Posted: 07/08/21 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Getting the truck right took longer because of the Covid related supply issues but I did this to simulate a full camper....
I had a full black and grey tank. Fresh was almost empty. Stocked the kitchen with pots and utensils and such. My clothes, camping gear like axe and battery powered chainsaw, a heavy tool box I will make much lighter. Truck had full fuel tank and full propane tanks.....
11,660. 160 over gross. The worst part is the rear axle is 7,300lbs which is 200 over GRAWR. Front axle was 4360lbs.
My thinking was the extra liquid weight would offset the absence of additional people. Black and grey tanks hold 30 gal. Each. Not sure how realistic a scenario this was...
jimh425
Western MT
Posted: 07/08/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
That’s better than most. The dirty little secret is most people are over even with a DRW because the trucks weigh more and the very long TCs weigh more. I’m under normally, but I would have been over with another couple and pulling a TT even with my 9 1/2 ft TC and 14500 GVWR.
I found with my SRW that I drove for years … the truck handled a lot differently with black/grey tanks full due to where the tanks are. That rearward weight isn’t noticable on my much heavier DRW. Both were setup the same way with the same TC except for shocks. My F450 handled great even with 4 people and pulling a TT.
Kayteg1
California > Nevada
Posted: 07/08/21 08:35am Link  |  Quote  |  Print  |  Notify Moderator
How are you holding tanks located?
On my 12' campers, they were in the very rear, so 60 gallons @ 8 lb would add 480 lb waste weight, or placed 7' behind rear axle 600-700 lb added to the rear suspension.
Empty the tanks before each longer drive.
In my case 200lb of gray water made for rig purposing .
phillyg
SWFL
Posted: 07/08/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
What truck and TC please?
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Longshore
California
Posted: 07/08/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Sorry phillyg. Truck Is a 2015 GMC CCSB 3500 SRW with Timbren SES. Camper is a 2021 Wolf Creek 890. The head is just forward of gravity center, black tank runs long way on the right side, but most of that tank is rearward. The fresh tank is visable under the step up to the bunk, but I have not seen the grey. It must be on the left side and run long ways. I figured that I would leave on a trip with a full fresh tank and empty black and grey. Also there was no groceries in the fridg.
Buzzcut1
Norcal
Posted: 07/08/21 11:44am Link  |  Quote  |  Print  |  Notify Moderator
If that's an srw and the rear axle is scaling at 7300 you better check your tire ratings.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Longshore
California
Posted: 07/08/21 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
Yup Buzzcut tires are next. 3525 ain't gonna be enough with this much on the tail. But the black and grey tanks run north and south, and I'm not sure how much is rearward. When I go off with the family they will be in the truck, all luggage will be as far forward as possible and the fresh water tank would be full.
Might be time to explore spare tire relocation? But tires are next.....
Kayteg1
California > Nevada
Posted: 07/08/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
So with your camper we can assume your holding tanks have COG close to camper COG, what is very close to the rear axle.
So dumping tanks will lower rear load by 480lb.
Relocating spare tire on front bumper will lower rear axle load by about 200lb, but it looks redneck.
Longshore
California
Posted: 07/08/21 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed Kayteg1. Not a good look. I am waiting on a call back for some F rated tires.
Buzzcut1
Norcal
Posted: 07/08/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
On my old SRW I was at 7450 on the rear axle with the truck and camper loaded to camp. Had a blow out running Toyo Opencounrty LT285/75R16 rated at 3750.
Swapped to Vision heavy hauler 19.5 Wheels and Cooper Roadmaster rm253 Tires 245/79/R19.5 both rated at 4500 Pounds and never looked back
Page of 11
