RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel pin lubricate
 > 5th wheel pin lubricate
Sagebrush
Jacksonville AL
Posted: 07/09/21 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
I use an old white plastic lube plate that stays on the trailer/kingpin, I also lightly use a lithium based grease on the hitch plate for rust prevention. Any wheel bearing grease can be used though, put the grease on the king pin and it will lube the hitch jaws too.
LadyRVer
Posted: 07/09/21 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Dealer suggested the Teflon disc. Used one from the very beginning. Also, lubricated the fifth-wheel hitch with white grease maybe once a year.
larry barnhart
wenatchee. wa usa
Posted: 07/09/21 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Retired JSO wrote:
We use a disc along with white grease on the pin itself.
same for us. chevman
chevman
2019 rockwood 34 ft fifth wheel
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
ramyankee
North Idaho/Kootenai Country
Posted: 07/10/21 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Lately, every time I go out to storage miny disc has fallen off the pin. I go to push it back on and there is resistance so it does fit tight. Next time I am out there thinking of putting it in the truck box...
Rick and Patti ">
2 Proud Christian CONSERVATIVES ">
2002 Chevy Silverado, 8.1, Crew, LB, 3.73, 4X4
2020 Mesa Ridge 291rls
Now living in North Idaho (formerly Northeastern California) ... but the heart is with MONTANA STATE UNIVERSITY
Cummins12V98
on the road
Posted: 07/10/21 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
Lay it on concrete and hit all around the the edge of the center hole with a hammer. This will shrink the diameter of the hole and make a tighter fit.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
blofgren
Surrey, B.C.
Posted: 07/11/21 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
And for us for many years.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
laknox
Arizona
Posted: 07/12/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Be aware that there =are= differing thicknesses of the disks and a few hitches simply don't have the clearance for even the thin disk to fit and allow the hitch to latch properly. At least from my reading various RV fora over the past 15 years.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
Cummins12V98
on the road
Posted: 07/12/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Lyle
The B&W is best to use a 1/8" disk than the 1/4".
fj12ryder
Platte City, MO
Posted: 07/12/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Will the 1/4" work? I bought one and thought it was a bit thick, but don't have a trailer to check. I may exchange it for the thinner one. I was thinking the last one I had was thinner than the 1/4" one.
Howard and Peggy
"Don't Panic"
Cummins12V98
on the road
Posted: 07/12/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I used one and it worked but you will like the 1/8” much better.
