RV.Net Open Roads Forum: Mystery Damage to my truck. From the camper??
 > Mystery Damage to my truck. From the camper??
wnjj
Cornelius, Oregon
Posted: 07/09/21 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
MN Ben wrote:
There is no dent. Id doesn't look scratched. It is worn or rubbed smooth.
That makes me think it was just barely in contact and the slack in the jack mounting when stowed was enough to sit and rub with light pressure. Can the jack ever get any closer? I see they lift up to pivot before dropping down. If you hold it up out of the lock slot, can it move any closer to the truck?
The truck cab and bed move much more independently than you might expect. Did you drive through something slow but twisty (like up an angled driveway cut)?
Even with snug tie-downs campers will shift in the bed. Did you drive through any strong crosswinds?
noteven
Turtle Island
Posted: 07/10/21 04:55am Link  |  Quote  |  Print  |  Notify Moderator
I had almost the same thing - my camper moved enough for a jack leg to touch the truck. The cushy rubber matting wasn't quite enough to stop the bit of movement.
I did what kayteg said ^^ about blocking the camper side to side so it cannot move enoough for the jacks to touch.
Angles and what not make loading it much easier.
MN Ben
Minnesota
Posted: 07/10/21 05:56am Link  |  Quote  |  Print  |  Notify Moderator
I had one 10 mile section of porpoising road which sucked to drive on. This is the only thing that I think could have caused the paint to rub off. I just cannot imagine the legs getting so close to the truck. My brothers driveway was at a sucky angle but only traveled over it up and down one time. Not much cross wind and solid with the semi trucks passing.
The jack cannot rotate any closer in-word, even if it was lifted above the locking points.
I'll make some blocks to put in the front of the bed. I don't do bodywork so fixing the paint will be a pain for me.
Thank you every one for your help!
2006 F350 Dually PSD
2004 Lance 1130
2002 F250 7.3 PSD -SOLD
2005 Lance 981 -SOLD
2000 Lance 1010-SOLD
199? Texan 650 -SOLD
Ford FX4 Ranger -SOLD
silverbullet555
Boise
Posted: 07/10/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
MN Ben wrote:
silverbullet555 wrote:
Your trailer is rocking back and forth in the bed which is independent of the cab, or the cab is rocking back and forth. In either case, the body bushings are where it's likely rocking and it is moving enough to make contact. Could be cab is moving one way and camper the other on rough roads, over bumps, etc.
Even with the Fast Guns attached? It happened on one side but not the other.
Yeah. I'm not sure why. Loaded to the side, crooked, etc. The fast guns are better than bed mount in my opinion, but there is still movement of the bed and cab.
If this is new damage, think back to your last trip. Rough, washboard, bumpy roads. High winds while driving, etc. Maybe the cab moved and the camper stayed. They are on separate body mounts and I've watched ours move quite a bit in relation to each other.
It's clear where the damage occurred from. We are trying to solve why and how.
1995 Northland Grizzly 860. 2355 lbs of purple goodness! Sold
2005 Lance 845 - Baby Bertha
2007 Chevy Silverado 2500HD Classic CC SB 4WD
Torklift mounts
Torklift superhitch
Hellwig swaybar and 3500lb helper springs
2002 Cobalt 226 "Baby Blue"
MORSNOW
Mountain Home, ID
Posted: 07/10/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
MN Ben wrote:
I originally thought this was from my camper. I have absolutely no clue. I made a video in hopes someone would know what caused this. https://youtu.be/djhJfPwoNlA
MNBen
Your issue shows the big weakness with TorkLift tie downs. The anchor points are almost vertical with most trucks/campers so they don't hold the camper from dancing around in the truck box (left/right, front/back). You need more triangulation to hold the camper from moving any direction in the truck box. HappiJac gets beat up here many times, but their holding angles are far superior and your camper stays put.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
jimh425
Western MT
Posted: 07/10/21 09:11am Link  |  Quote  |  Print  |  Notify Moderator
If what you said was true, all of us with Torklift tie downs would have the same issue. But, we don’t. There is literally only and inch or two left over for most TCs in between the wheel wells no matter what brand of tie downs you use. It could be possible that the OP doesn’t have their fastguns adjusted correctly.
I’ll stick with this is a case of the DRW hinge being mounted wrong, so it is far too close to the body.
noteven
Turtle Island
Posted: 07/10/21 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I prefer to block the camper from lateral movement at the bottom of it's frame where it sits on the bed and allow some vertical movement through spring loaded tie downs.
My F-350 is a bit of a flexi frame compared to my Dodge 3500 so I like to have the camper not ferociously tied down at the corners so when the truck frame racks a bit crossing ditches and such during light off roading the vertical force is not applied to the caamper which is trying to be a stiff box and maintain it's shape. I have actually released the rear two tie downs on a section of little wash crossings on the diagonal to get to a camp spot. The bed actually seperated from the bottom of the camper momentarily as the truck flexed through the spots.
My side box blocking holds the camper side to side but it can float away from the bed a bit if it has to.
If you never articulate your truck over anything more severe than a gas station approach then horsing down on all 4 corners of the camper is probably ok and triangles are better. I'm always wanting to drive across a forest road drain ditch or a wash or something to see what's over there...
In a pickup I'm still in the camp that says the camper needs to be blocked at the bottom to keep it from moving side to side or forward.
mr_andyj
Georgia
Posted: 07/10/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
If TC was going to stay on a few weeks or more I would take the front legs off and store them in truck cab. By that I mean I did this on mine.
It is obviously the legs rubbing. If no dent then it is barely rubbing, so you might can just move the leg farther out barely and then it will barely miss.
BradW
Mayor of Flat Rock
Posted: 07/11/21 01:00am Link  |  Quote  |  Print  |  Notify Moderator
MN Ben wrote:
jimh425 wrote:
Looks to me like the DRW brackets are installed wrong. They should be parallel to the TC sides, but appear to angled toward the cab.
Btw, it’s normal for the TC to move side to side some. You just have minimal clearance.
When I originally had these brackets one was angled in and the other was flipped and more inline with the camper side. I needed all the clearance I could get so I flipped the one. This made the jack straight out when unloading giving me the most clearance and angled towards the cab when folded in. I actually made the 3" extensions to give me more clearance. Maybe now I could try the brackets reversed. Maybe.
As Jim said, something ain't right. I've had two Lance campers and the jacks only had two positions, either straight out from the camper (loading/unloading) or straight forward (driving). They weren't angled in towards the truck cab were they were close enough to touch the cab when the camper rocks around while driving.
* This post was edited 07/11/21 01:12am by BradW *
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
joerg68
St. Ingbert, Germany
Posted: 07/11/21 05:10am Link  |  Quote  |  Print  |  Notify Moderator
Our camper is hardly ever on the truck completely straight, with the camper centerline being right on top of the truck centerline. Depending on where you load, it can be very difficult to back under the camper in an absolutely straight and center line, and usually being off an inch or so does not create a problem. At some point, it is just "good enough".
Even in the video you can see there are three fingers distance on the driver side and two fingers on the passenger side, indicating that the front of the camper is slightly off center.
