RV.Net Open Roads Forum: Mystery Damage to my truck. From the camper??
 > Mystery Damage to my truck. From the camper??
MN Ben
Minnesota
Posted: 07/09/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I originally thought this was from my camper. I have absolutely no clue. I made a video in hopes someone would know what caused this. https://youtu.be/djhJfPwoNlA
MNBen
2006 F350 Dually PSD
2004 Lance 1130
2002 F250 7.3 PSD -SOLD
2005 Lance 981 -SOLD
2000 Lance 1010-SOLD
199? Texan 650 -SOLD
Ford FX4 Ranger -SOLD
silverbullet555
Boise
Posted: 07/09/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Your trailer is rocking back and forth in the bed which is independent of the cab, or the cab is rocking back and forth. In either case, the body bushings are where it's likely rocking and it is moving enough to make contact. Could be cab is moving one way and camper the other on rough roads, over bumps, etc.
1995 Northland Grizzly 860. 2355 lbs of purple goodness! Sold
2005 Lance 845 - Baby Bertha
2007 Chevy Silverado 2500HD Classic CC SB 4WD
Torklift mounts
Torklift superhitch
Hellwig swaybar and 3500lb helper springs
2002 Cobalt 226 "Baby Blue"
jimh406
Western MT
Posted: 07/09/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Looks to me like the DRW brackets are installed wrong. They should be parallel to the TC sides, but appear to angled toward the cab.
Btw, it’s normal for the TC to move side to side some. You just have minimal clearance.
MN Ben
Minnesota
Posted: 07/09/21 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Even with the Fast Guns attached? It happened on one side but not the other.
jimh406
Western MT
Posted: 07/09/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe swap sides for the brackets. Pictures would help since it’s hard to pause the video to see it clearly, for me.
MN Ben
Minnesota
Posted: 07/09/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
When I originally had these brackets one was angled in and the other was flipped and more inline with the camper side. I needed all the clearance I could get so I flipped the one. This made the jack straight out when unloading giving me the most clearance and angled towards the cab when folded in. I actually made the 3" extensions to give me more clearance. Maybe now I could try the brackets reversed. Maybe.
Kayteg1
California > Nevada
Posted: 07/09/21 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
For my camper set I made a 2x6 plank, who made front wall stop and than I screw small 4x4 block to the ends, to hold the camper from side movement.
Tops of 4x4 have some taper for easy camper loading.
I also experienced that fast guns tension is crucial. I had my camper on factory rubber mat, yet on the 1st trip the camper move 1 inch to the back. The rocking motion during driving combined with air drag made it.
Than I put about 3/4" tension on spring-loaded fastguns and the problem did not come back.
MN Ben
Minnesota
Posted: 07/09/21 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Than I put about 3/4" tension on spring-loaded fast guns and the problem did not come back.
I have a mat under it. I like your 4x4 block idea. 3/4" on the fast guns??? Wholly Cow that seems like a lot of tension.
MN Ben
Minnesota
Posted: 07/09/21 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
There is no dent. Id doesn't look scratched. It is worn or rubbed smooth.
NRALIFR
Let’s Go Girls! [End of Quote]
Posted: 07/09/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
This just happened right? Was it unusually windy or bumpy on your last trip? I’d say your camper got a little sideways in the bed at some point.
Years ago, I was having strong headwinds and side winds occasionally move my camper a surprising amount, despite the fact that the tiedowns were tight, and the camper is sitting on a rubber mat. I eventually made some modifications to the bottom of the camper, and made a centering fixture for the truck bed to keep it from moving around.
[emoticon][emoticon]
