RV.Net Open Roads Forum: Tech Issues: 12 volt AGM battery
 > 12 volt AGM battery
NamMedevac 70
Reno
Posted: 07/12/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Is it true 12 volt AGM batteries do not last as long as wet cell bat if the wet is maintained properly. I heard this on the internet and just checking before next impendending purchase. I am talking about both bats being of similar quality.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 07/12/21 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
My American made AGMs in my previous DP only lasted 10 years. You can build a 100 AH Lithium for not much more than a good AGM.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
MNRon
Tennessee
Posted: 07/12/21 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Lifeline. They are not cheap, but last and perform better than cheaper ones. If you only want a battery to last 2-3 years, or want to run them down to 11v, then just buy the cheap ones. If you take care of them and want them to last 10yrs, Lifelines are worth it. On the other hand, if you REALLY want to spend $$$$, get lithium’s [emoticon]
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
toedtoes
California
Posted: 07/12/21 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
My optima lasted 8 years - until the thieves ran it dead. My boss has had his for more than 10 years. I disagree that they will only last 2-3 years. Watch the discharge and they can last far longer.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
MNRon
Tennessee
Posted: 07/12/21 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Toed toes - last I looked Optima’s weren’t’cheap’ batteries. For about the same price you could get Lifelines that come with lots of technical info backing up performance expectations. https://batteryguys.com/collections/lifeline/products/lifeline-gpl-27t
toedtoes
California
Posted: 07/12/21 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
No they aren't. From everything I've read, I can expect the same performance with the vmax agms at a better price.
I looked at the lifeline, but I needed three batteries. One for the clipper house, one for the trailer jack/brake, and one for the trailer house battery. I just didn't have the funds for the lifeline or optima. If the vmax fails, I'll post an update. But I expect them to do fine as I never let them drop below 75 percent.
Also putting in a new PD converter charger tomorrow.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 07/13/21 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Lithium battery popularity exploits weak areas in flooded and absorbed glass mat battery maintenance requirements. If the batteries are not maintained correctly, battery life suffers.
It is only after proper maintenance has been performed over the course of the unit lifetime can an intelligent assessment be made. There can be no quibbling about this.
dougrainer
Carrolton, Texas
Posted: 07/13/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Lifeline batteries are warrantied for 5 years. They are VERY good, but expensive. BUT, Lifeline batteries CANNOT recover from going completely DEAD. The just will not come back. Normal deep cycle batteries can recover from being dead as long as you recharge at the rate they were discharged. Lifeline battery warranty has a catch 22. They are warrantied for 5 years. BUT, if they fail before 5 years, it is because you let them go dead.[emoticon] Not a defect in the battery but user abuse. Doug
Almot
out there
Posted: 07/13/21 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
bgum wrote:
Need opinions on best 12 volt AGM battery for the dollar. At one time batteries in the $75-$125 range met this requirement. What say you.
$125 for a deep cycle AGM? More like $225 for a decent brand like Deka, this would be their small-ish size 90 AH. 105 AH would cost $260-280.
Even Chinese AGM cost well over $125 for 100 AH, and I would stay away from those. Had this experience already - no, thanks.
MEXICOWANDERER
Posted: 07/14/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
April 2020 I disconnected the 31 Lifeline. It measured 12.66 last week. The 2-story has been recharged to 14.4 volts overnight @ 75F and disconnected. These batteries were purchased in 2012, and 2013, respectively.
Yes, both capacity and load test. Capacity is 94 and 96%
Yes, they are Lifelines. No, they are not regularly full cycled.
