RV.Net Open Roads Forum: Problem with U-Haul refill. Time replace my propane tanks?
 > Problem with U-Haul refill. Time replace my propane tanks?
bobbolotune
Chicago Area
Posted: 07/12/21 02:55am Link  |  Quote  |  Print  |  Notify Moderator
My truck camper has 20 lb upright removable propane tanks. There are a few dings on the tanks with some minor rust in the ding. I needed propane while in Las Vegas and found a local U-Haul and she said that she shouldn’t fill it because of the ding. But she filled it anyway because she knew it would become an argument if she didn’t.
I saw the same thing on the U-Haul website that they won’t fill tanks with surface damage or if flaws have been painted over. Of course I can (and probably should) sand and paint over the dings, but that won’t help for U-Haul.
I have spent hours on google searches trying to understand if I need to replace these tanks. With no luck because it keeps popping up other topics. One thing that did pop up (and causes problems in the searches) is that the horizontal permanently installed tanks are much thicker so some rust isn’t a problem. But the 20 lb upright removable propane tanks are thinner, and it is unclear if U-Haul is being overly cautious or if a few dings actually are a problem.
Seems a new tank is around $30 each, plus I would need to find a place that knows how to purge the new tank. Also I am not clear if tanks for BBQs from a local store are good enough for RVs, or if you want a better quality.
I doubt if it is necessary to replace the tanks but it is a problem if I drive through a city (and city traffic) to a propane fill place and they refuse to fill the tank. On the interstate I fill up at Pilot / Flying J and they don’t question it. But off the interstate sometimes U-Haul is the easiest (or only) local option for tank refill, and if they give me a hard time that is a problem.
The tanks are 5 years old with a few dings. Is it time to replace the tanks?
Lance 850 truck camper
2016 Ram 3500 regular cab long bed 4x4 DRW 6.4L HEMI gas
pbeverly
South Carolina
Posted: 07/12/21 04:22am Link  |  Quote  |  Print  |  Notify Moderator
I found this, states if dented they can't be refilled.
Link
Ridgeway, SC
Tvov
CT
Posted: 07/12/21 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Yes. Pretty much any damage, and they have to be replaced according to whoever makes the regulations. As you found out, some places may still refill them just to make the customer happy.
Is there a difference between "BBQ" propane tanks and "RV" propane tanks?
2008 F-250 CrewCab 5.4L,
gbopp
The Keystone State
Posted: 07/12/21 04:46am Link  |  Quote  |  Print  |  Notify Moderator
I don't know but, I'm guessing the only difference is the price.
larry cad
ohio
Posted: 07/12/21 04:47am Link  |  Quote  |  Print  |  Notify Moderator
Horizontal permanently installed tanks are "TANKS"
20 lb upright removable tanks are "CYLINDERS"
There is a significant difference and RVers should know the difference in construction and RVers should know the difference.
Propane Cylinders for transportation are built to Department of Transportation (DOT) specificaions and their capacity is expressed in pounds of water. A popular example of a propane cylinder is one used the size used on barbeques known as a 20 pounds cylinder. Cylinder sizes range from a portable 5lbs cylinder to a residental storage size of a 420lbs cylinder.
Propane Tanks for permanent installation are built to American Society of Mechanical Engineers (ASME) boiler and pressure vessel standards and their capacity is expressed in US Gallons. An example of a ASME Tank is supply for a backup generator, a horizontial 500 gallon tank.
Our Travel Blog
rhagfo
Portland, OR
Posted: 07/12/21 06:35am Link  |  Quote  |  Print  |  Notify Moderator
A cylinder is a cylinder, the previous two cylinders I have bought I got at a propane distributor. The last I got at HD and had it filled at a distributor, the vacuum purged tag had been torn off so they purged at no cost with the fill.
NRALIFR
Truck Camping Out West
Posted: 07/12/21 06:52am Link  |  Quote  |  Print  |  Notify Moderator
If it has any dents, dings, or any pitting caused by rust, replace it.
You have a DOT cylinder, and a DOT cylinder is a DOT cylinder is a DOT cylinder. Doesn’t matter if the cylinder is going to end up on a BBQ or an RV.
Also, be happy you have the “upright” (vertical) 20 lb cylinder vs. horizontal, as those are the most common, and therefore the least expensive to replace. Another nice thing about a new cylinder is that you won’t have to worry about recertification for 12 years.
[emoticon][emoticon]
mockturtle
AZ
Posted: 07/12/21 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Just replace the tanks. [emoticon]
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
Lynnmor
Red Lion
Posted: 07/12/21 07:16am Link  |  Quote  |  Print  |  Notify Moderator
I take mine to the local Amish hardware store because he uses common sense in determining condition, and also has the best price on propane and cylinders. Maybe you can find a better supplier.
dougrainer
Carrolton, Texas
Posted: 07/12/21 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Laws are Laws. Just because a "Amish" does not follow the law does not make it safe. Doug
