RV.Net Open Roads Forum: Tech Issues: Question on Hydraulic Fluid
 > Question on Hydraulic Fluid
dougrainer
Carrolton, Texas
Posted: 07/13/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
ChuckSteed wrote:
If the fluid in the Lippert level up is clear it is NOT transmission fluid…
It is AW32 hydraulic oil.. nit all Lippert level up systems come from factory with Red ATF.. it depends on the builder and what they use..
My 2014 Keystone Alpine has clear fluid and is most certainly AW32..
Here is LCI official list. I am NOT a Oil engineer or expert on HYD oils but I can read and follow directions. I am also a Master Certified RV Tech with factory training in both LCI/Powergear and HWH. In ALL training, they stated to use Dexron 3 and NEVER TO USE HYDRAULIC FLUID. I have worked on both HYD Jack and slide systems for 35 years. If this list shows AW32, please list which it is. CLEAR Transmission fluid is available from HWH. It IS Dexron 3 without the red dye. You cannot look at clear(gold) fluid and state it is NOT Transmission fluid. Doug
PS for very easy use, just use Dexron 3
https://lci-support-doc.s3.amazonaws.com........veling-and-stabilization/ccd_0002088.pdf
RHasse
So Cal
Posted: 07/13/21 10:34am Link  |  Quote  |  Print  |  Notify Moderator
ATF has a very distinctive odor, you should be able to recognize it pretty easily. if you aren't familiar with it, just check the transmission dipstick on your car. Take a wiff of that, that odor is very distinctive, hard to miss even if you have a bad sense of smell.
Also, this isn't a very demanding application, it's not like its a tractor digging or moving dirt all day long; it's not going to make a huge difference what you use. There is not a lot of danger in mixing common oils like this, the additive chemistry may not be a perfect match, but there shouldn't be a problem with negative reactions occurring if you added ATF into a system originally filled with anti-wear hydraulic oil, or vice versa. The important thing noted in a message above is DO NOT USE BRAKE FLUID!. Brake fluid is a particular type of fluid that if you added it into your leveling system it would damage the seals and you'd have to have the entire system rebuilt.
dougrainer
Carrolton, Texas
Posted: 07/13/21 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Both HWH and LCI state, that if you use the wrong Fluid, it will cause problems with the operation of the seals and/or leaks. Doug
Edd505
Elephant Butte, NM
Posted: 07/14/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Lippert recommendations:
Operation Conditions
1. Above Freezing
NOTE: Operation at air temperatures routinely above 0°C (32°F). * A. Dexron 3/Mercon ATF
B. Mercon 5 ATF
C. Dexron 6 ATF
D. PetroBlend (Mason City, IA) PHO 0022S (synthetic group 3 base blend)
E. Bellman all temp 22 (Bremen, IN)
F. Or any ATF or hydraulic fluid with a pour point lower than -42°C (-45°F).
*Covers most initial OEM fills 2. Below Freezing
NOTE: Operation at air temperatures routinely below 0°C (32°F).
A. Mobil 1 full synthetic ATF
B. Royal Purple full synthetic ATF
C. Valvoline full synthetic ATF
D. Amzoil full synthetic ATF
E. PetroBlend (Mason City, IA) PHO 0022S (synthetic group 3 base blend)
F. Bellman all temp 22 (Bremen, IN)
G. Or any ATF or hydraulic fluid with a pour point lower than -42°C (-45°F)
H. Multivis (all temperature) iso 22 hydraulic fluid
I. Or any ATF or hydraulic fluid (conventional or synthetic) with a pour point lower than -46°C(-50°F).
3. Extreme Cold
Or any conventional or synthetic ATF or hydraulic fluid with a pour point less than -57°C (-70°F) and viscosity less than 2850 cP @ -40°C (-40°F ).
Do not use ATF-TYPE F fluid as it will not allow the seals to work properly.
Contact us: Lippert Components Inc. -www.lci1.com/customerservice- Phone: (574) 537-8900 - Email[emoticon]arranty@lci1.com
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Posted: 07/14/21 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, so much passion about camper hydraulics….lol.
2017 Heartland Torque T29
Posted: 07/14/21 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
OP, you have to check the level when everything is retracted.
I’ve never even seen camper hydraulics but I’m sure they work like any other. And half full tank with Rams extended sounds aboot right to me
Cummins12V98
on the road
Posted: 07/14/21 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting. AMZ/OIL is on their list. I used it right after delivery in 2015. Guess my recommendation is approved.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Ron3rd
Upland, CA USA
Posted: 07/14/21 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
southernsky wrote:
Make sure all your hydraulics are retracted...slides in and leveling system is up. Then check level. Our Lippert system uses auto trans fluid.
X2 Makes a big difference in the level in the reservoir.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
